Old 02-23-2019, 06:09 AM   #1
Scuba6801's Avatar
2017 27' International
Changing inline water filter
Is it best to remove the sink to change the inline water filter in a 2017 International Serenity?
Scuba6801 is offline   Reply With Quote
Old 02-23-2019, 06:46 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Our inline water filter is easily changed under the sink. The pex tubing is not fastened to the cabinet, but rather on j-brackets, allowing the whole assembly to be moved a bit. The end fittings on the pex are hand tightened, but both hands are needed - one to hold the filter and the other to loosen the fitting. Our trailer came with a straight length of pex with threaded end fittings to use to replace the filter when winterizing the trailer.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Replacement Inline Water Filter Astro2 Water Heaters, Filters & Pumps 21 12-07-2017 01:55 PM
Inline water filter direction bbruntil Plumbing - Systems & Fixtures 4 11-05-2017 10:10 AM
Inline water filter, why not a whole house canister? Vitaver Plumbing - Systems & Fixtures 23 11-08-2016 10:26 PM
Best inline water filter. schoochie11 Water Heaters, Filters & Pumps 1 12-06-2015 11:51 AM
