Old 09-07-2003, 08:04 PM   #1
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Can my toilet be repaired?
It's a Thetford Aqua Magic SL. The freshwater inlet valve is leaking, but the rest of the toilet seems fine.
Given that I can figure out where the Elusive Rear Nut lives, are parts available to fix the valve?
..... or is it New Toilet Time?
Thanks!
Don
Old 09-07-2003, 09:19 PM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Thetford
Here's a note from their WEBSITE :
Call Thetford's Customer Relations Department at 1-800-521-3032 to find out where the nearest of the 400 Thetford Certified Service Centers (shops which stock parts) are located.
Good luck.
Rog
P.S.: They also have step by step INSTRUCTIONS for removing the toilet.
Rog0525 is offline   Reply With Quote
Old 09-08-2003, 06:24 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yep, you can replace the ball valve. They sell the ball valve replacement kit at CW...and probably alot of other places, too. the hardest part for me was removing/re-installing the toilet. Once the toilet was removed, it was easy to replace the valve.
Old 09-08-2003, 06:51 AM   #4
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
had to remove mine this weekend . dont know if you have the
el cheapo shut off valve well i do and it come apart. the line nut is in the rear i tok mine off as it was only hand tight.
had to remove to find the rubber gasket that goes inside the nut . was a breeze to get it of. but to put it back was a pain.
i used a 1/4 inch rachet and long extension with 1/2 inch deep well socket put a universal on the end as it isnt a straight shot at the nut. or a flexible extension was what i used to get the nut back on. and tighten with the universal joint. need to tape all this together. i used black electrical tape. for the front nut i used a rachet wrench . lol
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 09-08-2003, 09:17 PM   #5
drboyd's Avatar
1978 25' Tradewind
Well, so far the answer...
...to my own question is, "yes."
Here's what I found out:
After doing the Special Secret Nut Calesthentics and ripping the poor toilet out by the roots, I started looking around inside. What I noticed was that several of the hoses were very, very old and nasty looking. Plus, they looked like they had stretched on the ends and were loose. I replaced all the hoses with new vinyl and double-clamped the pressure connections at the valve and the other end of that hose.
So far (knock on wood) no leaks!
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 01:28 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 09:57 PM
Toilet replacement Globestream Sinks, Showers & Toilets 2 09-23-2003 11:52 AM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 02:44 PM
