Old 07-05-2010, 06:57 AM   #1
1966 22' Safari
Davis City , Iowa
Question Can it be fixed? Toilet in 66 Safari
I have lots of questions. First: Are these repairable? I tested the toilet last week and water leaked between the porcelain bowl and the base. The gaskets look shot so I think I would need to replace all of them. I started to dismantle the toilet and have most of it apart with the exception of the screws that hold the valve mechanism to the china bowl. These screws seem to turn but not so I can remove the plate. What is the secret? I remember reading about someone fixing the toilet using parts from a hardware store last year but cannot find the thread If it is fixable where do I find the parts to fix it? If not is the Sealand Travel Lite the best choice for a replacement? One of these days I will get this finished.
drowe42 is offline   Reply With Quote
Old 07-05-2010, 07:55 AM   #2
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
I think you would be better off w/ a new toilet and sealand is what I will probably go with. the problem is it will not fit under the bench; also it extends out too far. The bench will have to be cut. Read the thread by member rburditt he has a thread 1965 Safari Bathroom Renovation-COMPLETED. Lots of good ideas there.
Kevin
kevinb is offline   Reply With Quote
'66 Safari Toilet Bench Mystery ASwifey 1966 - 1968 Safari 3 07-12-2011 10:55 PM
Toilet replacement for 1969 SAFARI Protosport Sinks, Showers & Toilets 0 07-25-2008 11:18 PM
65 Safari Toilet Parts? Kevo Sinks, Showers & Toilets 3 12-31-2006 09:38 PM
66 Safari Toilet givrdad Sinks, Showers & Toilets 1 06-20-2006 03:17 PM
How to modify toilet for long term fixed usage? haynes Waste Systems, Tanks & Totes 0 05-26-2004 04:31 AM
