Old 10-27-2011, 08:35 AM   #1
1973 31' Sovereign
Charleston , South Carolina
Bravura Install Question
Repaced my Aqua Magic Galaxy 30 on my 73 Soverign with a new Bravura.
This Bravura is not seated and rocks, old galaxy seated firmly to flange.
also seat cover hits vent shaft on left and vanity counter top on right.
So did any one have problem with seating this unit?
Thanks.
Jim.
cuyd is offline   Reply With Quote
Old 10-27-2011, 10:20 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Be sure that the rubber bottom seal is put on correctly (up/down orientation) and that the flange bolts line up properly. The outer rim of the Bravura should be directly on the floor and not touching the floor flange.
Tighten the flange bolts and you should not be rockin' or rollin'.
Old 10-27-2011, 10:28 AM   #3
1974 Argosy 20
Kooskia , Idaho
I replaced the Aqua Magic on my 20' Argosy with a Bravura but because it is deeper in the back, I had to cut the silly little storage compartment behind the toilet off, the one that was there on the Argosy. I like the Bravura, because it is a larger toilet, but because it is larger, it is not a direct replacement for toilets in close quarters. Thetford does not make this clear in their literature.
I had no problems with the flange, or seating. Mine is solid, like the original was.
Old 10-27-2011, 10:44 AM   #4
1983 31' Excella
Troy , Ohio
Check the directions for the proper locations for the mounting bolts. My old toilet had the bolts at 11:00 and 5:00 and the Bravua suggests 9:00 and 3:00.
rmk110761 is offline   Reply With Quote
Old 10-27-2011, 03:58 PM   #5
1973 31' Sovereign
Thanks for input.
I will pull toilet to look at the closet flange seal, Thetford Tech support said this is the best replacement because of same bolt placement. (11 and 5) i can modify seat but i can't puy up with a {rocky} Bravura.
Thanks.
Jim.
Onan install – ’05 30’ Classic GetOutDoors Generators & Solar Power 16 09-10-2012 06:59 AM
Towing Question from a novice imaginair Tow Vehicles 13 10-20-2011 07:15 PM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
A question on selling awnings Airy Awnings 21 04-24-2011 10:37 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
