Old 01-10-2019, 08:28 PM   #1
2018 25' International
Sioux Falls , South Dakota
Brand New Lavy Sink is Tarnishing???
We have a 2018 Rear Twin 25' International Signature. Last December 5th, our Airstream dealer replaced our stainless-steel lavatory sink at no charge because its was tarnished along its sides.
We have been camping since then. As shown below, the tarnish is beginning to return.
Is this a common occurrence? What could we be doing to cause this? How can we remove the current tarnish? Is there a way to prevent more tarnishing?
ID:	331474   Click image for larger version
ID:	331476   Click image for larger version
DaytonaDan is offline   Reply With Quote
Old 01-10-2019, 09:02 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Barkeeper's friend in liquid formula?
Old 01-10-2019, 11:25 PM   #3
2002 19' Bambi
Lafayette , California
There are various types of stainless steel and none of them are truly stainless. As AtomicNo13 says, Barkeeper's Friend would probably take off the spots. In truth, practically any metal polish or something like Soft Scrub would, too. Even toothpaste will usually work. Cleaning agents containing bleach of any sort are not a good idea nor is something like pure Clorox. Bleach is an oxidizing agent that any steel, stainless or not, will react to. Rust is the result.
Tim
Tim A. is offline   Reply With Quote
Old 01-11-2019, 06:56 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
This particular model sink I believe has been used in some fashion on trailers dating back to 2003ish as far as I can tell. My 2004, built in late 2003, has this same sink in the back of the rig. I haven't had any surface issues in 15 years with the sink itself. Only issue I have is that the drain plug closes on it's own once in a while. One time when I was flushing out the lines and just caught the water before it ran over the top of the sink. Of course, who knows if it's the same company providing the sink 15 years later. As has been pointed out, there are a few different levels of "stainless" out there and just about 2x the vendors that make that style sink.
I've used stainless cleaner on mine, Pledge, lemon and regular scrubbing bubbles, Windex for general cleaning and shine, not leaving crud on the surface very long either. Not entirely sure I remember right, but I might even have put a coat of car wax on it after I cleaned it on days my OCD meds aren't quite dialed in right--(tongue in cheek, I'm not really on OCD meds), but if I did wax my sink, maybe I should be.
If this is your second sink, a call to the factory might not be a bad idea at this point. They may have switched vendors and that vendor is supplying them with an inferior sink compared to the previous units?! I haven't been looking regularly, but this is the first time I've heard of such a problem with the stainless sinks...and I've heard, read and exp first hand a lot of issues, but none with the stainless sinks. Since yours is a 2018, perhaps something changed recently that the factory isn't even aware of yet.
Old 01-11-2019, 08:14 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have had three Airstreams over the last thirteen years. All had a similar stainless steel sink to yours. We have used our Airstreams extensively and have never seen the corrosive condition of your sink.
I believe that I would start with a Mr. Clean Magic Eraser or similar product and move up to something more abrasive if necessary.
This situation is most likely the result of Airstream's supplier using a low grade stainless in the manufacture of these sink bowls.
Btian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 01-11-2019, 10:28 AM   #6
caz
2018 30' Flying Cloud
Elgin , Texas
DaytonaDan,
We have a 2018 Flying Cloud 30. Do not have the tarnish issue shown in your photos. We always wipe the sink dry after every use. Perhaps that helps.
Bill Caz.
caz is offline   Reply With Quote
Old 01-11-2019, 11:35 AM   #7
2018 23' International
Crescent City , California
Very common. We use Barkeeper's Friend and polish when needed.
Gun2Head is offline   Reply With Quote
Old 01-11-2019, 11:53 AM   #8
1981 31' Excella II
New Market , Alabama
Try scotch bright in a circular fashion in the direction to the lines that are already there. If there are pits left then the alloy is not good. Usually caused by not enough chromium in the alloy. Also aggressive cleaning solvents and long term exposure to salts and bleach can cause pitting. A lesser abrasive would be those white polishing sponges.
Perry
Old 01-11-2019, 12:21 PM   #9
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
I have to agree with moosetags, most likely inferior SS, sourced from China.
Has anyone ever seen a similar problem with their homes Kitchen SS sinks? Probably not.
I would contact mother ship, and see what they have to say.
heslinhotel is offline   Reply With Quote
Old 01-11-2019, 01:32 PM   #10
Napa , California
Barkeeper's Friend will remove the crude, and gentle use of a Stainless Steel Polish (Sprayway Stainless Steel Cleaner works very well, Original Bee's Wax Spray or Pledge) will enhance the shine and add a barrier to whatever is causing the issue.
We had a brand new, very expensive stainless sink in our house and the painters cleaned some brushes in it that instantly started this same problem "latex paint, what could possibly go wrong?". I demanded a new sink, but the repair man offered to clean it up and monitor it (the general contractor was on call to pay for it if it didn't clean up to perfection). Barkeeper's friend and Sprayway worked and it has looked like brand new for five years now.
Be aware since you have had this issue twice it may be related to some product you are using in the trailer. Tooth whiteners or mouthwash? Bug Spray? Hair Spray? Spray antiperspirant? Astringent soap or chemical cleaners? Wiping the sink out after using will help to alleviate issues as well.
Atwebs is offline   Reply With Quote
Old 01-11-2019, 03:32 PM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I suspect you used bleach at some point to clean the sink. Bleach is an oxidizer, which probably rusted impurities in the stainless alloy causing the rusty spots. Bar Keepers Friend contains oxalic acid, which will help reduce the appearance of those Rusty spots. Using a wax or other sealant isn't a good idea.
Old 01-11-2019, 05:40 PM   #12
Fallbrook , California
This has happened/is happening to us too.I had never used anything harsh on the sink, only water and mild green soap cleanser. They replaced our sink, and our stove top and all our vent covers (which were all showing rust? discoloration of some sort too)... our sink is strating to show again the same, but not as bad spots. I'm worried it is just the way it is and we have to accept it as normal.
After several camping trips, I hardly notice it anymore because I think I have moved on into acceptance...good or bad. I'll try some of the suggestions too.
Roaminhomies is offline   Reply With Quote
Old 01-11-2019, 05:42 PM   #13
I agree, and accept this is the problem that can't be overcome, since I have already had the sink repaired and notice it again on my 2017 Flying Cloud
Old 01-11-2019, 08:29 PM   #14
2019 25' International
Washington , Washington, D.C.
When cleaning your sinks, always wash it going with the grain of the sink. I've always used Scrubbing Bubbles spray on sink and toilet with good (fast) results.
PatLee is offline   Reply With Quote
Replacing 2014 27FB sink with vessel sink Wishing Sinks, Showers & Toilets 15 08-30-2018 08:05 AM
2014 Sprinter kitchen sink faucet loose from sink base AirHammar Plumbing - Systems & Fixtures 0 11-15-2016 12:11 PM
How do I remove leaky sink drain pipe, bathroom sink, 1970 Sovereign NevaH Plumbing - Systems & Fixtures 4 09-14-2015 05:01 PM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 04:50 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 07:17 PM
