Old 07-08-2012, 04:46 PM   #1
2008 23' International CCD
Denver , Colorado
We want to install a Nature's Head composting toilet in our 23' 2008 International. Before I start taking things out: what is the purpose of this wood box between factory toilet and black tank? Is it simply to support toilet above the tank? Does the black tank extend up into this box? Photo attached (I think - yes! Twice!)
ID:	162716   Click image for larger version
Jim and Marsha
"Tow'd Hall"
AIR #35886
JimmyT is offline   Reply With Quote
Old 07-08-2012, 05:20 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
How large is your black tank?
The box may be hiding plumbing for the shower and/or sink.
Michelle TAC MT-0
Sarah, Snowball
Old 07-08-2012, 05:56 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
In my trailer the box under the head is the blackwater tank.
MICHAEL
Old 07-09-2012, 09:07 PM   #4
Denver , Colorado
Black water tank is 18 gallons. Yes, there is some plumbing running through that box to the shower. We would have to move or somehow cover those lines when we remove this box to install the composting toilet. But I'm hoping the black water tank itself is below floor level and we won't have to remove that tank.
Jim and Marsha
"Tow'd Hall"
AIR #35886
Old 07-10-2012, 08:26 PM   #5
Keymar , Maryland
If there plumbing in the box your tank is likely under the floor. The tank should be white. the will be a large pipe directly from the toilet to the tank.
Michelle TAC MT-0
Sarah, Snowball
Old 07-10-2012, 10:17 PM   #6
Denver , Colorado
Ah, yes, the large pipe which we can see when we open the toilet "flapper" valve and look down to the black water tank. That makes sense,thank you Sarah and Snowball. I'm going to go on that assumption unless I hear otherwise.
Jim and Marsha
"Tow'd Hall"
AIR #35886
