Old 09-02-2003, 03:21 PM   #15
Images: 59
Bizzare
Toater: also, on someone else's post, I saw solution to the venting problem. Air admittance valves-[URL=www.rectorseal.com/aav.htm]
markdoane is online now   Reply With Quote
Old 09-02-2003, 06:25 PM   #16
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Mark: That works out really well. If my mis adjusted eye is wrong on mine and it is 54 inches between the rails that will work out great. A tank 52"x22"x4" would hold 19.8 gallons. If I let it hang 1 inch below the pan it would be 24.75 gallons. That's a reasonable gray water tank.
Yeah with that width baffles would be a must. 25 gallons would be 200lb roughly plus the weight of the tank. Hmmm If I can get the tank right behind the axle I think 200lb would not be a big issue if on the rare occasion I had to drive a little before I found a place to dump. That will actually put it right in line with the rear spring hangers (no duraflex on ours. it has leaf springs). That would alow me to put a second dump right behind a tire where it's fairly well protected.
As luck would have it I can access a drain right in my own yard LOL . Thanks to new building codes when my neighbor hooked to city sewer they now have to put a clean out at the connection. That so happend to end up in my yard. I cut the top off 4 inches below grade because it looked like hell. I know exactly where it is LOL.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-02-2003, 06:34 PM   #17
Images: 59
Toilette bizarro
Yeah, I agree the slosshing probaby won't be a problem if located near the centerline and down low.
When our sewer was put in, they dug a trench through my neighbors yard, then a quick right angle and short run to my house. We don't have clean-outs. In Minnesota the sewers need to run at least 6ft underground or they freeze up.
Old 09-03-2003, 06:32 AM   #18
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Mark - nice looking '59 Trade Wind. Where was yours made? I've found three '59 Trade Wind's, including mine, that the serial numbers are within 18 of each others. What is your serial number? This is getting really interesting.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 09-03-2003, 07:19 AM   #19
Images: 59
Toilet bizardo
S/N 249082. Ordered the day after Christmas, 1958, shipped April Fools Day, 1959. Ohio plant. Price was $4814, less $1814 trade-in (1952 Silver Streak Clipper Delux), net $3000.
My wife's uncle bought this new, and took her to Yellowstone and Banf when she was a child.
Old 09-03-2003, 07:33 AM   #20
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Thanks Mark - yours id the first Ohio built one I've encountered. Cool to know the history of the trailer, wish I was so lucky.
FF
Old 09-03-2003, 10:21 AM   #21
Penguin's Avatar
Some places are better than others
All you-all who are writing about putting in a gray-water tank:
I looked at a 68 Overlander this week at South Jersey RV, a place that does repair and restoration work on Airstreams. They put a gray-water tank underneath, inside a metal box-looking contraption, and the whole thing was behind the axles and about 8 inches off the ground!
My uneducated take was that a speed bump would catch this thing, and there are LOTS of speed bumps in campgrounds!
Penguin is offline   Reply With Quote
Old 09-03-2003, 10:32 AM   #22
Images: 59
toilet
Thanks Penguin. Sometimes we forget where the hazards are.
Old 09-03-2003, 12:16 PM   #23
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: Some places are better than others
If it's close to the axle that's not really as bad as it sounds. The problem is out towards the bumper.
To put it into perspective my last DD that I drove for 4 years sat no more the 6 inches off the ground at the front spoiler and rocker pannels and I never dragged it on a speed bump. Got the front lip on a few parking ties and curbs though.
1959 22' Caravanner
Atlanta, GA
Old 09-03-2003, 12:55 PM   #24
Images: 59
toiletbowl
Toaster: Whats a DD? Is that a Dodge Dart?
Old 09-03-2003, 01:25 PM   #25
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Re: toiletbowl
DD = Daily Driver the day to day car we drive.
abe
vajeep is offline   Reply With Quote
Toilet changing tips... drboyd Sinks, Showers & Toilets 2 07-18-2006 01:28 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
64 Swirlomatic toilet MW64OVERLANDER Sinks, Showers & Toilets 1 10-27-2003 09:57 PM
remove/reinstalling the toilet Chuck Sinks, Showers & Toilets 7 07-28-2003 02:44 PM
Toilet seat cover overlander76 Sinks, Showers & Toilets 6 07-27-2003 10:50 PM
