Old 06-13-2015, 04:59 AM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Best RV Toilet?
I'm replacing the toilet in our 86 Limited. Bathroom room is a premium. I thought I wanted a Thetford Aqua Magic V as it has outside dimensions similar to the old Thetford that's in there not. The old one has developed a leak in the flush valve.
I was shocked to learn the new Thetford toilet does not have a "down pipe" from the bowl to the floor. The water just spills into the lower chamber of the toilet and a "gravity" directs the water to the black tank. The whole lower chamber of the toilet is "dirty". I can't imagine I would want one of those. I understand it is sealed, but removal would be a mess.
My new Dometic 310 in my Trade Wind has a molded in down pipe as I would expect. The Dometic is too big for my 86 Limited. No room for that big, oval shaped bowl and seat.
So, like tow vehicles and hitches, I figured I'd start a "toilet review" thread and see what you experts have found for good replacement toilet. I want a good design. Too bad Toto doesn't make an RV toilet.
David
dbj216 is online now   Reply With Quote
Old 06-13-2015, 07:17 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Personally I think the best head for trailers would be a quality composting unit.
MICHAEL
Old 06-13-2015, 08:03 AM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Keep the discussion coming. My toilet works, an Aquamagic V I believe but it is like a child's toilet to me- prefer a residential elongated. Not a huge issue but the throne is a bit small! Still,it is better than a bucket and a walmart bag!
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-13-2015, 02:54 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I'm not ready for a composting toilet. Reminds me of my cat's litter box.
The "residential" style toilets are too big for the space I have. Airstream designed this bathroom very efficiently. They probably picked the shower pan and toilet and designed the room around it. That is what I did in my Trade Wind.
The Dometic 310 I have in my Trade Wind wasn't all that impressively built. The plastic connection male nipple had a 1/4" long un-threaded extension on it. I suppose it reached down to the rubber seal on some type of toilet swivel connectors. But the flex connector I had did not allow room for that long extension. I had to mess around too long to get the thing connected. Plastic threads never impressed me. And the flange seal wasn't just the best design I have seen either. Further, the bowl is big, but it is shallow. I don't know how well it flushes yet.
The Thetford Aqua Magic V is the right size. But the plastic flush valve and mechanism sits high in the back of the toilet. And this design with no down pipe just bothers me. I can't imagine. It's like having two black tanks, one above the floor as part of the toilet, and one under the floor. The old Thetford had the slide valve down at floor level. There was almost 6" of down pipe molded right into the bowl.
So I was just wondering what other Airstreamers have found that seems well built and functions good.
David
Old 10-12-2015, 04:01 PM   #5
LivLoveLaugh's Avatar
2012 30' International
South Western , Pennsylvania
Wouldn't give 2 cents for the Dometic 310 High Profile toilet that came with our 2012 AS. The toilet leaks at the seam between the bowl and base. There is no way to repair this. Took the toilet out and you can hear the water that has accumulated in the pedestal. We are currently looking for a replacement but I guarantee I will not buy a Dometic.
Sometimes I pretent to be Normal....
but it gets boring, so I go back to being me
LivLoveLaugh is offline   Reply With Quote
Old 10-12-2015, 04:10 PM   #6
1972 27' Overlander
Woodburn , Oregon
I just installed a dometic 320 in my refurbished overlander looks great but I haven't had it long enough to give you a honest report
shineybullet is offline   Reply With Quote
Old 10-12-2015, 05:21 PM   #7
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
I think if you were really boondocking the composting would be the way to go. Having a wet bath, not really an appealing option though (apparently has been done). Would consider the urine/waste separator units though and the solar full time fan connection manditory.
Resale value you'll likely have to return to original config before you sell though.
timhortons is offline   Reply With Quote
Old 05-06-2017, 07:37 PM   #8
Atl Bch , Florida
If i were boondocking, I would use a bucket with a toilet lid. Since I'm not, I would like a decent high profile RV toilet. I have been looking at the Dometic 310 since it flushes with water [understanding that the hose needs to be longer]. I am also looking at the "Aqua-Magic Residence High Profile, White RV Toilet".
While I can appreciate everyone has different tastes, I am like the original poster. I want a toilet as close to what I would have in a regular house as possible. Preferably with an elongated bowl. Any other brands recommended that are under $200?
SilverSunny is offline   Reply With Quote
Old 05-07-2017, 05:25 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
In the last three years I have installed three of these dang toilets.
I installed a Thetford Aqua Magic 5 in the 69 Globetrotter this winter. It's best feature was the low price. I needed a "shorty" at 15" high as the Globetrotter has this rather horrible above floor black tank and fiberglass "wet" bath surround. I needed a hand lever flush instead of the foot pedal.
It has one of those rinse hoses that only works when you have the lever in flush with the water running. The hose connection leaked right out of the box, easy fix. The swirl and rinse action is pretty good. Photo 2 below.
The Trade Wind Dometic is not terrible either. At least it has a down pipe. It rinses clean. This one is 18" high. Photo 1 below.
The Aqua Magic is probably the volume leader in the RV toilet market. We bought a Thetford Buvera about 16" high for our other trailer. It is a little better built than the Aqua Magic. It has fancy "contemporary" artistic styling. Big deal. My butt doesn't care. Photo 3 below:
But all these toilets are a lot better than a bucket. Good sanitary procedures are key to good health in public areas. Anyone have a list of diseases spread by human waste?
David
Name:	1405 Bath Sink and Toilet (Small).jpg
ID:	284986   Click image for larger version
Name:	1703 Toilet Mounted (Mobile).JPG
Name:	1510 Toilet New (Small).JPG
Old 05-09-2018, 03:13 PM   #10
1988 34' Excella
Emery , South Dakota
I bought a thetford aqua magic V high profile. i am ready to install but steel plate on my 1989 Excello 1000 three axel 34 ft does not have fastening bolts properly lined for this toilet. I am stumped at how to realign the steel plate, tried turning with no luck. Tried to remove and refasten to the floor, no luck. Anyone have any help
braudtjerry7 is offline   Reply With Quote
Old 05-09-2018, 04:52 PM   #11
Mollysdad's Avatar
Best RV toilet? IMO, the simplest one.
Step on a lever and the "stuff" falls into the black tank.
A bonus would be a tall one with a decent sized seat.
My current AS has this magic toilet where the pipe makes six 90 degree bends before reaching the black tank, some going up!
I've avoided it like the plague.
Old 05-09-2018, 05:03 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not understand what you are trying to say about the toilet bowl and lower chamber and no pipe? I just installed a Aqua 5 toilet in my trailer and it certainly has a pipe if you call it that from the bowl to below the outlet. The bowl valve is at the top of the "pipe" and the seal mounts on the bottom of it. Everything that is in the bowl goes directly into the inlet to the blackwater tank. And yes, it all goes by gravity.
It is a cheap, lightweight, plastic toilet. But it fits the space I need it to and the old one that it replaced lasted 30 years with one re seal job. I opted for the hand flush. On my other trailer that has the toilet mounted on the floor instead of a raised platform I put in one of the taller toilets with a ceramic bowl and it has been good.
I have the platform rebuilt and can change out the toilet in 30 min or less if I have a problem with it or just want one that looks new if this one ages.
Old 05-09-2018, 07:02 PM   #13
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Maybe I mentioned the wrong model number or it was an older design. But I clearly remember looking at a Thetford toilet with no down pipe. Dirty water just dropped into the lower part of the toilet and then drained into the black tank. I couldn't believe what I was looking at, and certainly didn't buy it. Dometic did have a down pipe and that's the main reason I want that way.
I agree, simple is best.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 05-09-2018, 08:28 PM   #14
Stay Calm and Stream On
2017 25' Flying Cloud
Palm Springs , California
The best thing I did was to upgrade the toilet seat to porcelain and a 1 inch rise in seat height. The Dometic that came in my 2017 25a FC works great.
HHPJ is offline   Reply With Quote
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Best new toilet for 70 overlander? jesus mike Sinks, Showers & Toilets 5 11-16-2007 08:24 PM
What's the best replacement toilet? soldiermedic Sinks, Showers & Toilets 5 11-05-2006 09:30 AM
