Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 11-15-2007, 09:27 PM   #1
jesus mike
70 Overlander
jesus mike's Avatar
Profile:  1970 27' Overlander
jacksonville , Florida
Best new toilet for 70 overlander?
Ive looked as far back as 2005 in the forums and couldnt get a clear answer. Im looking for the most original looking/fitting and easiest to install toilet for my 70 overlander. From what ive gathered the sealand travelall lite is good. Has anyone put one in a simillar model before? Any help would be great, im putting in hardwood floors and want to do the toilet at the same time.
jesus mike is offline   Reply With Quote
Old 11-15-2007, 09:56 PM   #2
PizzaChop
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
I put one in a '72 Overlander a couple of years ago. I had to twist it slightly.
Nice toilet, much nicer than the original.
ID:	49389   Click image for larger version
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 11-16-2007, 12:34 AM   #3
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I put a Sealand low profile in my '72 GT. It has a china bowl and therefore is not original - I opted for functionality.
Fyrzowt is offline   Reply With Quote
Old 11-16-2007, 07:04 AM   #4
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
JM,
It depends on whether you are mounting flat to the floor or have to mount to a raised black tank. I have found the Sea-Land Traveler series to be very well made and easily serviceable. They have a pedal flush mechanism, and you can add water to the bowl easily by lifting the pedal before flushing.
They are offered in white, bone and several other colors and MSRP is around $285. The 500 series is particularly popular.
Of course, if you want to go totally deluxe, you can get the Concerto residential style with electric flush or a Thetford Aria II for about $700, or you could even go with a Microphor or HeadHunter which will quickly get you up into 4 figures!!! That's why they call some of them the 'throne'!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 11-16-2007, 08:17 PM   #5
jesus mike
70 Overlander
jesus mike's Avatar
Hey
Thanks for the info. Im not sure about the difference between the traveler 500 and the traveler lite. Is it just seat size? I see its a $70 diference, will both of them fit/work? I wont be using it too often so seat size isnt too important.
Old 11-16-2007, 09:24 PM   #6
lewster
Commercial Vendor
lewster's Avatar
Originally Posted by jesus mike
Hey
Both work...................
The difference is in the weight and build of the units. The 'lite' version is just that. The 500 series is much more substantial and IMHO, will last a lot longer than the 'lite' version. I see lots of the 500 series and less than a handful of the lite versions. Must be a reason that the EMs don't use them.
Plus, thinking of these rattling down the road....I'de go with the more substantial one.
AIR # 10325
Rebuilding '68 Overlander Toilet Uberlanders Sinks, Showers & Toilets 5 04-17-2005 10:37 PM
65 overlander toilet and base needed. ronmcor Parts Archive 3 11-10-2004 10:01 PM
What's under the toilet? Safari Tim Sinks, Showers & Toilets 18 07-09-2004 11:55 PM
Toilet FireFighter Sinks, Showers & Toilets 7 08-06-2003 02:56 PM
Toilet dmac On The Road... 1 06-27-2003 05:28 PM
