Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 02-02-2010, 12:25 PM   #1
2002 31' Classic
Caledon , Ontario
Bathroom sink stopper
I have a 2002 Classic and have a bathroom sink in which the plunger/stopper is stuck. Consequently I'm unable to 'close' the sink and fill it with water.
Any suggestions on how to fix it? Thanks.
sieve is offline   Reply With Quote
Old 02-02-2010, 02:30 PM   #2
Cantrell's Avatar
1985 34' Limited
1960 24' Tradewind
Summerville , South Carolina
Typically, the stopper is attached (by a hook in the end) to the actuating arm that moves the stopper up and down. Reach under the sink and unscrew the threaded cap where the arm goes into the drain (on the rear of the vertical drain pipe just under the sink). After you pull that arm out, you should be able to get the stopper out. Clean the stopper and reassemble with the arm going through the little hook in the end, rethread cap hand tight, and you should be good to go.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 02-03-2010, 06:55 AM   #3
2002 31' Classic
Caledon , Ontario
Thank you, Bill.
I'll try your suggestion. i appreciate your help.
bathroom sink Squid All Argosy Trailers 15 02-05-2009 07:43 PM
Bathroom Sink grovelander Cabinets, Counter Tops & Furnishings 2 10-20-2007 06:40 PM
Bathroom sink stained chuman70 Sinks, Showers & Toilets 8 09-07-2007 05:05 PM
Bathroom Sink Lee Pace Sinks, Showers & Toilets 1 08-20-2006 10:51 PM
Any suggestions for bathroom sink? yukionna General Interior Topics 2 08-02-2004 08:50 PM
