Old 08-02-2006, 09:41 AM   #1
1970 31' Sovereign
Curtis , Michigan
bathroom restoration
Hi - new to the AS lifestyle and just acquired my 1970 31" Sovereign.
Other than the mouse problem and some other minor maintenance the only overhaul I want done is the bathroom. I'm looking for someone to do the work for me. I live in the Upper Peninsula of Michigan and I'm looking for someone with this experience in Michigan or Upper Wisconsin. I'm open to suggestions on how to accomplish this. I saw some AS that had a resurface of the existing fixtures it looks like. I'm open to this too.
Any suggestions will be appreciated.
Thank you
nmloehr is offline   Reply With Quote
Old 08-03-2006, 07:21 PM   #2
I have done my bathroom over 2 years ago using Tough as Tile Tub and Tile finish from Lowes. I also used fiberglass mat and cloth with Gorilla glue to fix and fill broken corners and cracked plastic holes where rivets were used. I even refinished the original cloth like material covering the mode seat. Several folks have seen the results and claimed it looks like I used new tub sink, panels etc. If interested I can give you the formula for pigmenting the 2 part epoxy. The only drawback is the painting need to be done all at one time and within an hour or 2 at most after mixing the epoxy.
Live and LET live
FrenchBern is offline   Reply With Quote
Old 08-08-2006, 08:08 PM   #3
1970 31' Sovereign
Curtis , Michigan
Thanks FB I will keep it in mind.
Old 08-08-2006, 08:50 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Hi nmloehr -- guess I can still say, "Welcome to the Forums!" I found this by searching on: sink refinishing.
I always think of Kevin Allen (overlander64) in terms of refinishing sink and shower pans -- his photo album shows the results. So many home sink & tub surfaces are plastic these days and refinishing is available locally -- I think that's who Kevin used. Might find more info on that in search but I'd suggest checking your yellow pages.
It also took me to other DIY posts by balrgn on the same subject.
I showed Susie a thread back when our Argosy was a higher priority and she was sold on the idea -- somebody had refinished their sink & shower pan in ruby red! Quite impressive.
5 meter Langford Nahanni
Old 09-04-2006, 12:13 PM   #5
1970 31' Sovereign
Curtis , Michigan
THANKS FOR THE INFORMATION!
Old 05-01-2007, 10:06 AM   #6
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
The bathroom of our 79 31' Sovereign rear bath is sitting behind the trailer in pieces. I gutted the trailer and replaced the floor.
I want to paint the bathroom----using "Tough as Tile" tinted to an Olympic white.
QUESTION: Do I paint the pieces before I put them back in the trailer or before I put them back in the trailer?
I know there will be quite a bit of 'flexing' of the shower walls, sink, tub etc reinstalling them. If I paint them before I reinstall them will I run the risk of cracking the paint?
If I paint them after I reinstall them, will I be able to reach all the spots?
Jim Lee is offline   Reply With Quote
Old 05-01-2007, 12:21 PM   #7
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Images: 125
The trailer is a 1978, not a 1979.
sorry for the confusion
Old 03-23-2008, 06:35 PM   #8
SharonIvey's Avatar
1972 29' Ambassador
Red Oak , Texas
I would paint them first.
SharonIvey is offline   Reply With Quote
Blower in bathroom? uwe 1970-79 Tradewind 14 03-07-2008 09:40 PM
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 07:45 PM
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 02:15 AM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 06:36 AM
