Old 07-26-2009, 03:15 PM   #1
1969 31' Sovereign
Madelia , Minnesota
Bathroom remodel 69 sovereign
Hi everyone I am redoing the bathroom the whole thing is ripped out now and I am looking for ideas for a sink shower ect. the floor is soft so I plan on just putting plywood right over the top of the old one does anyone know if they make a thicker toilet base or what ever that black flange is called. Also I am looking for a shower base that the drain will be in about the same spot as the old one doest anyone know of one that will work?
Jay
jaychristens is offline   Reply With Quote
Old 07-26-2009, 06:43 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If your floor is bad you need to rip it out,and replace it,while you`e there you may find a little frame rot,rear end sag and nasty fiberglass. The plywood goes between the c-channel and the frame ,which gives it strength.You need to reuse your tub,just refinish it,or make a custom unit to fit the curve. Dave
easyride is offline   Reply With Quote
Old 07-26-2009, 07:58 PM   #3
Kevin245's Avatar
Hey Jay,
I definately would discourage the practice of overlaying any bad wood. You may very well get by for a while, but it's much easier to spend some extra time now to fix it correctly. This also gives you an opportunity to address any other underlaying issues that may also need attention.
Do you have the original bath components?
Regards,
Kevin
Eleanor Roosevelt
Old 07-27-2009, 07:29 AM   #4
1969 31' Sovereign
Madelia , Minnesota
No I donít have the original bath tub. The last guy used a sawzall to take it out. And as far as going over the top of the floor where I can see the frame on top and I have had the panel off below the black tank it looks good other then the metal casing around the tank thatís pretty bad but I donít think that really does to much does it? And the floor is only soft where the toilet was and the very back were the sink drain is.
Old 08-13-2009, 03:07 PM   #5
gutsgolf's Avatar
1972 31' Sovereign
Hattiesburg , Ms
Send a message via AIM to gutsgolf Send a message via Skype™ to gutsgolf
Kevin, i am going to take out a tub , sink and more what is it you need
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
gutsgolf is offline   Reply With Quote
Old 08-19-2009, 09:32 AM   #6
1972 29' Ambassador
trenton , Tennessee
Keep me in mind for the tub if Kevin is not in need....I need to install one in my 72 ambassador....
Pirate4hire is offline   Reply With Quote
'70s Rear Bathroom Remodel? mello mike Cabinets, Counter Tops & Furnishings 2 02-28-2012 07:40 PM
Bathroom Plumbing Remodel Silverslug75 General Interior Topics 6 07-16-2009 09:20 AM
Interior remodel on 79' Sovereign cookeville34 General Interior Topics 0 09-13-2006 08:21 PM
Bathroom Prep for my '72 Sovereign mello mike Sinks, Showers & Toilets 2 08-05-2005 11:50 AM
Kichen remodel - 85 Sovereign 25' j54mark Cabinets, Counter Tops & Furnishings 6 10-14-2003 06:20 AM
