Old 12-29-2005, 07:00 PM   #1
1965 26' Overlander
Acworth , Georgia
Bathroom Plastic is cracked
I have 65 Overlander, rear bath. Plastic section around tiolet is broken at floor. How do we replace/repair this?
PhilMateo is offline   Reply With Quote
Old 12-29-2005, 07:18 PM   #2
w5wi's Avatar
1976 25' Caravanner
1977 31' Sovereign
Richland , Missouri
Phil,
I've had good luck using the fiberglass repair kits that you can purchase at Home Depot or Lowe's or you can go to an auto parts store and buy the materials themselves.
I am unclear about where exactly the crack is. If it's in the toilet assembly I suggest removing the toilet and attempting the patch it from the inside.
w5wi is offline   Reply With Quote
Old 12-30-2005, 04:30 AM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I've had good luck with "POR EPOXY PUTTY" comes in stick form, you mix it like bread dough. Once it has taken set it can be sanded even drilled and tapped. Good luck!
http://www.por15.com/product.asp?productid=9
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Blower in bathroom? uwe 1970-79 Tradewind 14 03-07-2008 09:40 PM
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
