Old 03-28-2010, 04:27 PM   #1
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
Bathroom fiberglass color change?
In our 67 Safari the bath is a light yellow color...would like to make it a lighter color...white or off white...anyone have experience with changing the surface color ??
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 03-28-2010, 04:40 PM   #2
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Bathroom
There's a thread in here where you can treat it to make it (the abs plastic) white and remove the yellowish color. Here's one with some advice, but I think there is one where peroxide was used to whiten, the plastic.
Not all parts in the bathroom is fiberglass.
http://www.airforums.com/forums/f446...round-376.html
Richard
RichHog is offline   Reply With Quote
Old 03-28-2010, 05:30 PM   #3
If I remember correctly, the peroxide method is called "Retr0Bright" (number 0 in the name). You can google it. They use it to lighten old computer parts to make them like new and it removes the yellowing with some chemicals that mix into a gel, you paint it on and put some sun lamps or direct sun on it for periods of time, clean off and repeat. We bought all of the ingredients but decided to use TileDoc and epoxy the bath surfaces instead.
We will be using the Retr0Bright mix on the widnow openers and will post here the results. There is also a post on here somewhere of the Retr0Bright being used on AS plastic parts with good results.
Bathroom Fiberglass End Cap and Shower Question mello mike General Interior Topics 4 03-25-2010 04:29 PM
My 1975 Argosy 20' MH bathroom--ABS or fiberglass?? kdenault General Interior Topics 0 04-17-2009 11:24 AM
Bathroom fiberglass Dotti&Ditto Cabinets, Counter Tops & Furnishings 6 06-13-2005 12:35 PM
Interior color change William8979 Upholstery, Blinds, Walls & Interior Finishes 2 02-03-2005 02:04 PM
change color of fiberglass??? kent osborn Sinks, Showers & Toilets 3 10-05-2003 03:32 PM
