Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-06-2004, 11:36 PM   #1
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Bathroom faucet and toilet stuff
On our last outing I found the bathroom faucet was leaking into the rear closet. It is a 4" spacing with a shower diverter on top. Sink mounted.
I tried to get new o-rings but it still leaks. Also there is no gasket along the bottom of the faucet where it meets the the sink.
So I removed it and am looking for a replacement that will accept the shower wand. Any ideas?
Also, while I'm at it, I am thinking of replacing the toilet seal. If I pull the toilet, what are the chances I will be able to get a new seal for it? It's an original Aqua Magic.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 07-07-2004, 09:11 AM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Tim!
Finding a faucet with the shower diverter isn't a particular problem as the basic 4" spread faucet with diverter is still a common RV part. The problem will be if you want a metal unit (I am guessing that Airstream may have still been using metal faucets in the '70s as my '78 Argosy had metal faucets). RV dealers (even my favorite Airstream dealer) don't typically stock anything but the plastic variety faucets - - they are evidently available, but seem to often be a special order item. Since they are often the product of companies in the household plumbing areas, a plumbing supply house may be able to order what is needed from one of their catalogs.
The Aqua Magic in my Overlander dates to the mid-1970s, and my Airstream dealer hasn't had any problems getting new seals in each of the instances when it has been taken out for repairs over the past nine years.
Good luck with your search for a replacement faucet unit!
Kevin
Kevin D. Allen
AIR #827
Old 07-07-2004, 12:31 PM   #3
Safari Tim
Safari Tim's Avatar
Images: 35
Thanks Kevin for the info.
You right. I ended up picking up a plasitc one :-( from Camping World.
Don't want to hastle with this too much more. I'm sure it won't last 30 years though!
-Tim
Old 07-07-2004, 04:19 PM   #4
mtpalms
mtpalms's Avatar
Profile:  1971 23' Safari
Joshua Tree , California
If you still want to try to resurrect your original faucet, I posted this after replacing the valves on ours:
http://www.airforums.com/forum...ad.php?t=11016
mtpalms is offline   Reply With Quote
Old 07-07-2004, 04:45 PM   #5
airhead
Profile:
leaking faucet
Our kitchen faucet was leaking when the water was turned on. I took the valve down to Home Depot and to my surprise they had a matching pair. I installed them and no leaks. Ours is a Pfister Price brand in our 61 Overlander. I now have to do the same in the bath. Too easy!!!
Good Luck!
airhead is offline   Reply With Quote
Old 07-07-2004, 05:14 PM   #6
Safari Tim
Safari Tim's Avatar
Images: 35
Thanks, mtpalms.
I took the valve down and replaced all the orings and stuff and it still leaked.
Plus there is no gasket along the bottom where the faucet meets the sink.
So, I think I will just put the new cheap one it and keep the old one for a back up.
Like I said before, you can not really restore an airstream because the replacement parts are infereior ;-)
-Tim
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
advice wanted for bathroom sink replacement Shelby Copeland Interior Restoration Forum 8 12-25-2003 08:06 AM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 06:13 PM
Bathroom Door Tracking Out Of Alignment montanaandy Doors & Locks 2 07-12-2003 03:47 PM
Need some help and suggestions on bathroom escapeez Plumbing - Systems & Fixtures 2 05-14-2003 01:05 AM
