Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 01-15-2008, 09:28 PM   #1
out4trout
Profile:  1968 26' Overlander
stevensville , Montana
Bath Tub
Having a hard time getting the bath tub out of my 68 Overlander. I can't seem to be able to get to the drain pipe for the bath, in order to detach the the plumbing. A lot of my floor rot is between the bath tub and the toilet. Everything is coming out great accept for this tub.
out4trout is offline   Reply With Quote
Old 01-15-2008, 09:39 PM   #2
goransons
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
Yakima , Washington
can't you remove the drain's chrome ring with a spud wrench? Ours came out pretty easy though they used some great sealer under it. Guessing the P-trap is glued anyway so hard to remove from below (at least ours was, but that may have been a repair)
goransons is online now   Reply With Quote
Old 01-15-2008, 10:30 PM   #3
Mark Wiltrakis
Silver Hilton
Mark Wiltrakis's Avatar
Profile:  1992 29' Excella
1959 24' Tradewind
Hillsboro , Oregon
In my '59 Tradewind, the chrome piece in the tub floor seemed welded to the cast iron plumbing beneath the floor. I was unable to free it using a tool with 4 "arms" that engaged the chrome supports (spud wrench?), resulting in destruction of these supports. I treated the area several times with Kroil penetrating oil to (hopefully) loosen the parts. As a last resort, before sacrificing the floor of the tub, I cut two vertical slots into the chrome drain piece with a Sawzall, and used a pair of large screwdriver blades to rotate the chrome drain free from the cast iron P-trap below. It wasn't pretty, but I was able to remove the shower pan intact.
Mark Wiltrakis is online now   Reply With Quote
Bath tub area badly stained - suggestions? jonesgirl 1981 - 1983 Excella 8 12-06-2007 07:44 PM
Bath Tub Stained Really Bad Cleanable? lanajane Sinks, Showers & Toilets 2 04-30-2007 11:36 PM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 12:15 PM
Tub Repair Hawk_Man Sinks, Showers & Toilets 5 08-17-2006 06:18 PM
How do I remove the Tub??? Morning Dew Interior Restoration Forum 18 04-19-2004 11:47 AM
