Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 09-23-2018, 12:05 PM   #1
1980 22' Caravelle
Frederick , Maryland
AS Water System Antifreeze Lifespan
Can anyone tell me how long antifreeze is good for after it is added to protect an AirStream water system from freezing? I have had some health problems and haven't had opportunity to replace it for some time.
Ed Thompson
Scoteagle is offline   Reply With Quote
Old 11-04-2018, 06:29 PM   #2
Elk Rapids , Michigan
There shouldn't be any problems with anti-freeze not working over time, the ethanol or propylene glycol won't change into water and break your pipes. If it was winterized properly you should be fine indefinitely. There are plenty of other things that cause problems in storage though, especially the ones with tails
If you're worried, you could just drain it out at the low point. Any areas that don't drain completely will still have anti-freeze in them.
Hope your health improves soon and you can get out on the road again. For my money the best anti-freeze is taking the trailer to a place that stays warm in the winter
Cheers,
John
matthewsx is offline   Reply With Quote
Old 11-05-2018, 11:34 AM   #3
1980 22' Caravelle
Thanks, John
I got a response from another A/s list and he made it a joke. "You mean it might go bad??? Ha ha ha!!!" Your response was sane and to the point. I appreciate sanity and knowledgeability more the older I get. I will "winterize" it after the first of the year by going to Florida. In fact, I plan to move there next year. Thanks again. Ed
Old 11-05-2018, 11:47 AM   #4
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Stuff does indeed happen. Even automotive anti-freeze has a finite lifespan. If it's over about 4 years old, it's probably worth replacing it.
uncle_bob is offline   Reply With Quote
Antifreeze in the hot water heater RAH Winterizing, Storage, Carports & Covers 4 10-14-2013 09:56 PM
Lifespan of LT tires? blickcd Tires 1 03-22-2013 09:10 AM
ABS lifespan Flynavy Waste Systems, Tanks & Totes 0 08-21-2011 08:28 AM
Lifespan of GFI breaker? blickcd Lights - Interior & Exterior 7 07-07-2009 11:23 AM
Water heater, Engine antifreeze? shadejo General Motorhome Topics 3 08-28-2005 09:30 PM
