Old 12-09-2009, 07:53 PM   #29
Ottawa , ON
WoW!!! You have done a TON of work! Way to go, Cynthia!
So, don't worry about fixing a little bit of floor, Cynthia, you are so far in, that's only going to be one line in a great long list of fantastic things to do to your trailer.
And yes, it will be relatively easy to do as described above. As will the new PEX and bathroom layout.
I'm dying to see how you are going to do the new layout. Do you plan on using all the other existing AS furniture?
And thanks for posting your status so far. It will be a gorgeous trailer when you are done.
Aage
Old 12-11-2009, 08:40 PM   #30
1971 27' Overlander
Boulder City , Nevada
WOW!!! you really dig into it. Question; it looks like you've repainted the inside of the bathroom walls. Did you and what did you use? I sure don't like that icky yellow of our '71 AS.
zigzag is offline   Reply With Quote
Old 12-11-2009, 09:29 PM   #31
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Some trailer facets can be replaced with home facets. Others not so much. Some of the shower valves can't be found in regular store. Take my Caravel for example, the kitchen facet is a standard 4" center facet. A home kitchen sink would be 8" center, but a lav facet works because it's a 4" center. My shower is an unusual set up, a 4" center with a right angle hand shower thread. You can't find that. But, you could find a wall mount utilty facet and adapt the spout the fit a hand showerhead and mount it upside down. As long as the finish is bright you can rebuild a facet. New washers, seats and some plumbers grease would set a person back about $3.
Bigventure is offline   Reply With Quote
Old 12-12-2009, 10:25 AM   #32
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
ZigZ, No I have yet to paint the bathroom. Actually, its still dirty original behind the fixtures. Have a rear floor rot issue to deal with before paint.
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 12-12-2009, 10:37 AM   #33
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Have you tried Wood preservation, rot repair, and restoration using epoxy resin on boats and homes. products?
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 12-12-2009, 10:55 AM   #34
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Originally Posted by Dwight View Post
I have not. Thanks for the link. Ill give it a read.
Re-Chrome Faucets dnrtheil General Interior Topics 6 05-07-2009 07:34 AM
HELP-No water in any of the faucets??? shinybean Fresh Water Systems 10 11-23-2006 09:14 PM
Water faucets otha1 Sinks, Showers & Toilets 5 08-31-2003 10:05 AM
Can't seem to get H2O from faucets dinoburb Fresh Water Systems 11 08-11-2003 06:56 PM
