Old 07-21-2010, 12:15 PM   #1
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Scottsville , Virginia
Argosy toilet selection & the mystery of the secret compartment
We are replacing the toilet in our "new" 1978 Argosy, and it looks from other dated threads that the main replacement candidate due to space constraints is a "Bravura", I would rather a china toilet- maybe the Sealand Traveler Lite. Can anyone confirm that the Traveler Lite would work? the clearance is tight- 12" to the overhanging-secret compartment behind the toilet...
Wonder what the intended purpose of the secret compartment was- what are some good uses for it in your world ...?
Kathy
whitefawn is offline   Reply With Quote
Old 07-21-2010, 12:34 PM   #2
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
I recently saw someone suggest it was a laundry bin. Seems reasonable.
biggoofball is offline   Reply With Quote
Old 07-21-2010, 01:22 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
You must have tiny laundry. Our compartment is very small; it would hold a few pairs of socks perhaps.... and I always figured it was intended for girlie unmentionables or maybe a trashy paperback novel.
We have the low model of the sealand traveler lite in our argosy - it fits under the secret compartment but only just. It's a great pot however and has been hassle free.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-21-2010, 02:58 PM   #4
Whitefawn
whitefawn's Avatar
1978 Argosy 24
argosy toilet
Thanks- Does your toilet sit back under that compartment? And if so, how does the toilet seat open? The measurements for the Sealand Lite make it seem too big for that space...
Kathy
Old 07-21-2010, 03:03 PM   #5
Janet H's Avatar
1964 26' Overlander
Images: 90
Here is a pic New Sealand Toilet - This is a Sealand Traveler lite model and just fits with out modifing existing structure. China is good - Plastic Thetford be gone! Photo Gallery
The seat hinges are not all the way under the overhang. Also - we have an Argosy Minuet which is a little different than a standard argosy (smaller) but may be configured differently.
Old 07-21-2010, 06:59 PM   #6
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Thanks again- the picture is helpful. When I measured under the compartment from the floor of the toilet in our Argosy, I got 12 inches. Is that what yours measures? The bump on the back of the Sealand exceeds 12 inches- and I can't quite tell from the picture- on yours is that bump sitting in front of- rather than under the compartment? I prefer the china toilet and really want it to work!
Kathy
Old 07-22-2010, 10:32 AM   #7
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
Darrington , Washington
Kathy, let me assure you that the "Bravura", WILL NOT fit in your Argosy. I too have a 78 24 ' model. I was advised to get the "Bravura", and after buying it on line, I was sad to learn it will not fit without cutting the Secret Shelf out. You can install the bravura without the seat but it's rough on the rear end when you use it. My wife says cut the shelf, I'm looking for another toilet. I will be intersted in learning what you select and if it fits.
Keep in touch Thanks
buffaloman is offline   Reply With Quote
Old 07-22-2010, 11:09 AM   #8
Whitefawn
whitefawn's Avatar
1978 Argosy 24
I appreciate that news about the Bravura. I am leaning towards the Sealand Traveler Lite, even though on paper it looks like it won't fit. It would be a cryin' shame to get rid of that secret compartment!
Kathy
Old 07-22-2010, 11:17 AM   #9
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I will second this. We also have a '77' Minuet and used the Sealand Traveler Lite. It was a tight fit but it fit. Very happy with the choice.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 07-22-2010, 11:33 AM   #10
Janet H's Avatar
1964 26' Overlander
Images: 90
That 'bump' is a plastic cover that covers some of the plumbing bits. It is removable and here's a tip:
If the fit is too tight (by just a little) you can take that cover and shave a little off the bottom (think belt sander). It will still provide the needed protection but you can gain a little clearance.
Whitefawn - you might search the forum for sealand, argosy and see if you can find other members who have used this toilet and have a standard argosy. I am 90 percent certain it will fit, but it would be nice to confirm with a standard argosy owner.
Old 07-22-2010, 05:10 PM   #11
Whitefawn
whitefawn's Avatar
1978 Argosy 24
I am inclined to get the Traveler Lite and let my husband figure it out. I have searched this forum, and I have have to admit that I don't always get satifactory results when I search-- no doubt operator error, or what my friend calls PEBKAC- problem exists between keyboard and chair...
Kathy
Old 07-22-2010, 05:21 PM   #12
Janet H's Avatar
1964 26' Overlander
Images: 90
One note about the traveler lite.... it comes with a totally cheesy seat. I highly recommend buying a regular seat (which will fit) at lowes or walmart. Just take the old one with you when you shop to make sure you get the proper size.
Old 07-22-2010, 05:56 PM   #13
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Yes it IS a cheesy seat- we put that toilet model in our 1971 Overlander, which we just sold. We never got around to replacing the seat. It took a lot of fiddling to make it work in the Overlander, and if we have to do it again in the Argosy, we've had some practice.
Kathy
Old 07-22-2010, 07:00 PM   #14
1978 Argosy 27
Lacey , Washington
Images: 8
Hi,
I have been reading your discussion on the toilet and what will fit. I have the '78 27ft with the original yellow pot with the plastic lid. It is sort of cool (retro, now that those colors seem to be in vogue again but it is a very uncomfortable seat. Recently, while have some other plumbing fixtures replaced the toilet has "sprung a leak" and thus I am thinking it may be a good time to replace it for a more modern, more effecient and more comfortable toilet. In the 27ft the toilet is on the right side of the bathroom. Will the Sealand work there? I do not need to go under anthing because the toilet goes next to the back of the wall behind the toilet. I also have this "opening" that is about 2ft by 8" by 2ft deep that appears to be a useless space. So I am working on how to make it less useless. Thanks, for posting your toilet question. It got me to ask mine. jjustice
jjustice is offline   Reply With Quote
'66 Safari Toilet Bench Mystery ASwifey 1966 - 1968 Safari 3 07-12-2011 10:55 PM
Help with Toilet Selection Crawdad General Interior Topics 2 07-02-2010 06:19 PM
'78 Argosy 6 metre Minuet battery compartment door jholder45 All Argosy Trailers 3 06-01-2008 07:22 PM
Argosy toilet compartment door....F.O.C. MotorSeven All Argosy Trailers 0 03-02-2007 10:00 PM
Argosy Mystery Machine ShineOn Member Introductions 5 07-31-2006 06:12 PM
