Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-20-2014, 04:41 PM   #1
1979 23' Safari
Las Cruces , New Mexico
Argosy shower pan and liner
I have a small crack in a plastic shower pan in my Argosy 20 and some longer, fairly tight cracks in the upper side and head liner in my Minuet. I am going to take a stab at plastic welding but I need to know the type of plastic. Any engineer type know if this is ABS, PVC or ? I need to know because the rods are specific as to type.
Greg
apltrez is offline   Reply With Quote
Old 07-06-2014, 09:25 PM   #2
1983 31' Excella
Yulee , Florida
I would call the Argosy tech dept. and ask them. My Excella 31ft 1982 shower pan is vacuum formed ABS. It is disgracefully thin at the corners - in my opinion much too thin to plastic weld satisfactorily.
I have the same problem and I'm thinking of getting some sheet ABS, heat forming it into the corners, gluing with ABS cement and then faring it with filler and spray painting or rollering it. Of course, it requires prior cleaning, sanding etc and ditto at each stage.
Good Luck!
Norm
Greg
AFUser is offline   Reply With Quote
1947 Liner - "1006" :: 1947 Airstream Liner wdscentral Airstream Registry Discussions 3 04-07-2023 06:08 PM
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
1953 Liner :: 1953 Airstream Liner 57BB Airstream Registry Discussions 0 07-16-2013 04:05 PM
Painting the shower pan and sink? shermantic Sinks, Showers & Toilets 2 01-25-2009 08:40 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
