Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-20-2009, 05:23 PM   #1
Kelly Caravanner
Profile:  1970 25' Caravanner
Santa Rosa , California
Aqua Magic toilet removal
Hi, I just bought a '70 Caravanner from my uncle and it is in pretty decent shape aside from a few dents, some old window gaskets, some stove issues, and a water hose that just busted loose in a very hard to reach area (just finished replacing it with pex). Anyways, I am also having some issues with the toilet, the Aqua Magic has two pedals-- water and flush, and it looks like two stages on the water pedal.
My problem is: when the water pedal is pushed all the way down (stage two) water shoots up from behind the toilet. I am trying to remove the toilet, and have the two (I assume there are only two) bolts undone, but can't figure out how to disconnect the toilet from the drain.
Has anyone dealt with this style toilet and it's removal before?
Kelly
KC aravanner is offline   Reply With Quote
Old 06-20-2009, 07:24 PM   #2
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
If you have the 2 nuts off it should pull straight up,oh yes,disconnect the water.That is unless a PO used an adhesive to seal it down.Dave
easyride is offline   Reply With Quote
Old 06-20-2009, 07:31 PM   #3
Profile:  1968 24' Tradewind
Oxford, , Mississippi
Toilet removal
When I recently took the toilet out of my 68 TW, it came right up after removing the 2 closet bolts(along with most of the rotten floor). Be careful if you try to pry on the lower toilet flange, it does not take much to snap a piece off.
Old 06-20-2009, 08:10 PM   #4
Profile:  1999 25' Safari
Fairburn , Georgia
The water inlet hose screws onto the back of the toilet like a garden hose. The valve is very likely to freeze and split in cold weather if not completely drained. Most likely your problem. Good luck.
JackMac is offline   Reply With Quote
Old 06-21-2009, 01:04 AM   #5
Kelly Caravanner
Thanks to all who responded. I should have given it a try while I had the water disconnected, shouldn't be too hard to re-disconnect though now that I have new fittings and water line.
Old 06-21-2009, 08:02 AM   #6
nvestysly's Avatar
Profile:  1992 29' Excella
Metro , Atlanta
Be Sure To Check the Toilet Water Valve
It might be worth changing the water valve on the back of the toilet while you have a chance.
For less than $20 you can replace the valve that works with the 2 step foot pedal. These typically go bad after some number of years. Ours began to leak after 16 years and the leak was not noticeable. But it sure caused problems with our hardwood floors.
Lucius
Lucius and Danielle AIR#25 WBCCI#16771 WDCU
'92 - 29' Excella, '96 - GMC C2500 Suburban
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 06-21-2009, 12:47 PM   #7
Kelly Caravanner
Wow, Lucius, you called it. I've attached a picture of the valve, it is cracked in the back, and I think it did do a number on my floor. Any idea where the best place to find that valve would be?
Kelly
Old 06-21-2009, 12:48 PM   #8
Kelly Caravanner
I don't think that picture made it onto my last post, I try again.
Name:	Toilet Valve leak.jpg
Old 06-21-2009, 04:32 PM   #9
nvestysly's Avatar
Metro , Atlanta
Thetford Sells Them...
Thetford sells them as a kit and some RV suppliers have them on hand.
Aqua Magic Galaxy Parts
Be careful with the web page that I referred to above. There a several Aqua Magic models and I may not have selected the correct unit for your trailer.
Lucius
Old 06-22-2009, 12:20 AM   #10
Kelly Caravanner
Cool, thank you very much,
Kelly
Old 06-22-2009, 01:45 AM   #11
Very american 4 a french
brunoffrance's Avatar
Profile:  1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
Oups... that recalls me good souvenirs.... but curiously, no odor.... Hum,sorry if you 're dinning...
Bruno.
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 06-26-2009, 04:10 PM   #12
nvestysly's Avatar
Metro , Atlanta
KC aravanner,
What's the latest? Were you able to purchase a valve kit? How's the floor look?
I replaced my entire toilet since I was also having trouble with the blade in the bowl - it was not sealing. My floor was wet but a few days with a box fan blowing air across the floor solved most of my problems.
The oriented strand board was reasonably firm so I went ahead and put everything back together.
Lucius
Old 08-29-2009, 05:57 AM   #13
ryan3326's Avatar
Profile:  1976 31' Sovereign
Columbus , Indiana
Hello
Just curious to see if you were able to replace the valve and how difficult it was? I have the same issue with my '76 Sovereign.
ryan3326 is offline   Reply With Quote
Old 08-30-2009, 12:08 AM   #14
Kelly Caravanner
Yes, I did fix it. Amazingly the part that I ordered online worked! I was only amazed because it was a little bit different shape than the original. Apparently they don't make the original part any more, and the new one is in a 90 degree orientation to the way the old one sat. But, thankfully everything lined up and it works like new now.
Upgrade Thetford Aqua Magic V Toilet ?? 2dabeach Sinks, Showers & Toilets 12 04-14-2009 03:55 PM
aqua magic toilet repair captmorgan Waste Systems, Tanks & Totes 8 12-30-2008 12:53 AM
Replacement Toilet for Thetford Aqua Magic? JeepinAudiophile Sinks, Showers & Toilets 1 09-20-2004 12:05 PM
toilet:Sealand vs Aqua Magic dogwood Sinks, Showers & Toilets 8 09-02-2004 08:46 PM
Aqua Magic Toilet - 68 Globe Trotter Bryanhu Sinks, Showers & Toilets 0 06-30-2003 02:29 PM
