Old 03-27-2010, 08:12 PM   #1
Dallas , Texas
Anyone use Incinolet incinerator toilet?
- I N C I N O L E T -
INCINOLET uses electric heat to reduce human waste (urine, solids, paper) to a small amount of clean ash, which is dumped periodically into the garbage. INCINOLET remains clean because waste never touches the bowl surface. A bowl liner, dropped into the bowl prior to use, captures the waste, then both liner and its content drop into the incinerator chamber when the foot pedal is pushed. You can use INCINOLET at any time-even while it is in cycle.
A Typical Cycle:
Incineration cycle is started with the push button. Both heater and blower come on when button is pushed. Heater alternates off and on for a preset period of time, blower continues on until unit has cooled.
Several people may use the toilet in rapid succession. Push the start button after each use to reset the timer.
This looks like it would be the ultimate RV bathroom, but at $1,800 its not cheap. My main question is: DOES THIS WORK as advertised? I would love to maximize my options and build both toilet styles into my airstream if this is the real deal. Anyone have one? Has anyone used one?
Albatrill is offline   Reply With Quote
Old 03-28-2010, 07:44 AM   #2
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Would it require a huge amuont of electricity? What if you are boondocking?
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 03-28-2010, 08:26 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Power consumption would be a problem. 120V only 1800 or 3600 Watts, That is 15A or 30A.
Michelle TAC MT-0
Sarah, Snowball
Old 03-28-2010, 08:55 AM   #4
BeBop's Avatar
2000 27' Safari
Berkeley , California
You may wish to consider the Sun-Mar range of products. They have home/RV/boat models. Lower power consumption than an Incinolet, but equally expensive.
SUN-MAR. The Environmental Solution
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
BeBop is offline   Reply With Quote
Old 03-28-2010, 09:36 AM   #5
Dallas , Texas
BeBop, the sun mar looks great! I oftentimes find myself amazed at the inventions that come out of the eco movement - almost makes me want to hug a tree!
Old 03-28-2010, 11:00 AM   #6
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Try this site for composting commodes ... I am looking at this for mine.
http://www.natureshead.net/
Xbob2 is offline   Reply With Quote
Old 03-28-2010, 11:36 AM   #7
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
I have been around one at work. I refused to use it. When I first started in that area the vent would back draft. Imagine that smell. When we had heavy use it backed and the element burned out. Now we bring in portapotties when there is a work group that can't go back across the levee. They have found scorch marks on the ceiling where is exits the roof. The smell down wind stinks, the blower is noisy, and it pulls a lot of amps. This is a unit of last resort were nothing else is feasible.
"Humans get a lot done,not because we're smart, but because we have thumbs so we can make coffee." Flash Rosenburg
"Decaffinated coffee is the devil's blend."
GO Bob is offline   Reply With Quote
Old 03-28-2010, 11:46 AM   #8
1962 28' Ambassador
1962 30' Sovereign
There are 3 units mentioned in this thread ... which one are you referring to?
Old 03-28-2010, 05:54 PM   #9
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
INCINOLET Sorry.
Old 03-28-2010, 06:13 PM   #10
mcair's Avatar
1988 29' Excella
Collinsville , Illinois
I can't imagine spending that much $$$ for a toilet. Are you trying to eliminate holding tanks? With that setup you would not be able to boondock unless you want to bring a generator.
mcair is offline   Reply With Quote
Old 03-28-2010, 08:26 PM   #11
345bill's Avatar
Las Vegas , Nevada
I too remember them from where I worked. The smell was AWFUL! Theory was great but that's where it ended.
I'm sure the larger ones require ALOT of power. Not familar with smaller RV type, though. But still, the stink has to be the same.
345bill is offline   Reply With Quote
Old 03-28-2010, 08:27 PM   #12
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
We can highly recommend the Natures Head Composting Toilet. We have been using it full time for almost a year and it has worked very well. Yes, there is some maintenance involved, but every time we drive past the dump station and watch some poor guy struggling with the stinky slinky, we rejoice! Check them out at:
Nature's Head Composting Toilets - The Ideal Marine Toilet for Your Power Boat, Sailing Vessel, or Houseboat
FLYNCLD is offline   Reply With Quote
Old 03-28-2010, 08:29 PM   #13
FLYNCLD's Avatar
Bend , Oregon
PS-Almost no power requirement, no smell, no black tank, no dump stations, no problem!
Old 03-28-2010, 08:30 PM   #14
1962 28' Ambassador
1962 30' Sovereign
Have you guys plumed the "wet" side of the commode to a tank or go with the bottle? How long in the real world do you go before you have to dump the compost bin?
Incinerator toilet Tessa Sinks, Showers & Toilets 10 11-05-2008 09:58 PM
need a new toilet osolow Waste Systems, Tanks & Totes 1 10-12-2008 02:31 PM
New Toilet Jfuller678 Sinks, Showers & Toilets 7 01-04-2008 09:19 PM
What's under the toilet? Safari Tim Sinks, Showers & Toilets 18 07-09-2004 10:55 PM
