Aluminum Shower Wall Questions??
I have a 77 Ambassador with a rear bath. I have completely painted and refinished the bathroom with the exception of the back wall. I am looking at ideas and material to cover the shower side as well as the cabinet side and considering aluminum as demonstrated in the you tube video I recently viewed. My questions are as follows:
1. Do I need a special type of aluminum?
2. Does the aluminum need to be coated to resist water staining?
3. Is there a special cleaner needed to avoid permanent damage or staining?
4. Resources for purchase would also be helpful.
Aluminum looks easy enough to install but will take any suggestions specific to using another material (tile, shower wall?? etc.)
Thank you in advance for your help.
