Old 12-27-2008, 08:09 AM   #1
Haskell , Texas
Alternative uses for truck bed liner.
Has anyone tried the tintable Raptor truck bed liner to recoat the shower pan? Mine is pretty damaged and I am afraid when I get through with my repairs it may not be smooth enough to recoat with the traditional materials and not show a lot of uneven surfaces. The truck bed liner are supposed to be uv resistant, flexible, some texture as to avoid slipping is the shower, water proof and a lot of other good qualities. I was just wondering if this was totally off the wall.
knemir is offline   Reply With Quote
Old 12-27-2008, 09:31 AM   #2
It's your trailer and you should do whatever you like. I think rubberized bedliner would make a decent material for this application.
However, if you like the original look of the shower pan, I'm not sure I would give up too quickly on restoring it. There are many threads on this site regarding shower, tub, and bathroom counter renovations. I'm not too familiar with the 70s models, but I think your shower pan is made out of some type of ABS plastic (if I'm wrong I'm sure others who are more knowledgeable will correct me soon). And I believe many people have had success with sanding and then re-coating with durable, flexible epoxy paints.
Good luck!
Old 12-27-2008, 01:39 PM   #3
Jim Foster
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
When I mentioned your bed liner idea to my wife, the first thing she said was that the uneven surface may be difficult to keep clean. I thought the bed liner sounded good, but Lynn is the one who does most of the cleaning.
For what it's worth.
Old 12-27-2008, 02:29 PM   #4
Common Sense , Texas
Nothing to do with a shower pan, but I have used the rattle can spray on stuff from the auto parts strore to coat the front of utility trailer fenders to prevent rock chips, and it worked very well for that aplication.
In the shower pan area, I'd be concerned about the ruff texture, and the obvious cleaning problem. Think I would consider fiberglass cloth and resin as an alternative.
Old 12-27-2008, 02:45 PM   #5
Haskell , Texas
Thanks for all the good info, that is why I like this forum. Happy Holidays! KIM
Old 12-27-2008, 05:50 PM   #6
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
my nephew usede the bed liner on the entire truck he uses for 4 wheeling. he its trees and junk with the truck. wipes it clean with a rag and there is very little damage.
very tuff stuff
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Spray-in truck bed liner for shower tank? dsakaki Sinks, Showers & Toilets 9 02-14-2009 06:05 AM
8ft. versus 6ft. truck bed on crew cab chaimemet Tow Vehicles 30 12-18-2007 08:50 AM
bed liner for truck millvalleyca Tow Vehicles 39 08-25-2007 06:41 AM
Truck bed covers? Could use some help! maxandgeorgia Off Topic Forum 17 05-26-2004 10:45 AM
Bedrug bed liner j54mark Tow Vehicles 7 03-21-2004 08:31 PM
