Old 07-11-2012, 02:39 AM   #1
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Air Head Toilet
I have decided to install an AirHead composting toilet in my 66 Tradewind. Has anybody else installed an AirHead in their Airstream?
Thanks, Dan
Old 07-13-2012, 07:54 AM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Just bumping this thread to see if anybody has installed an Airhead composting toilet in their Airstream (or any other composting toilet for that matter)?
Thanks, Dan
Old 07-13-2012, 10:22 AM   #3
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
greenrvlife.com
ecodiscoverytour.com
LiLNomad is offline   Reply With Quote
Old 07-13-2012, 10:33 AM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I have read somewhere here about it but can't find it. But my question is why? let it compost in the ground not your trailer.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-13-2012, 10:52 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
After reading the specs I am not sure I see any benefit. It would appear that you would have to empty the liquid container every 2 days, assuming 2 people.
With care a conventional holding tank system will generate less than a gallon a day per person including flush water and solids. Our 10 gallon tank lasts 6 days for 2 of us.. In no hookup locations I can dump into a 5 gallon blue tank every 2 days and deposit it in a toilet or porta john if no dump station is available. It would seem you would be doing exactly the same thing with your liquid tank except it would be a few pounds lighter.
Now if there was a system that handled the liquids as well as the solids. didn't use any power, and fit in the trailer , you might have something.
But then you still need to deal with your wash water anyway.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-13-2012, 01:48 PM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Rick & purman
Thanks for the comments.
Here are my reasons for wanting to go to the Airhead:
1. My original toilet is 46 years old and is broken.
2. I only have one tank. With a composting toilet I don't need a black tank and my one tank now becomes a dedicated grey tank.
3. The Airhead has gotten good reviews from sailboat owners.
4. I would not be using this toilet for solids every day and would probably use it for liquids only at night as there are usually toilet facilities where we go boondocking. I don't think dumping the urine bottle every few days is a big deal at all.
5. Supposedly you can have 80 throne sessions before dumping the waste. We can probably go a year or so before dumping.
6. I think the Airhead is small enough to fit my Tradewind. I will have to make some modifications, but I would have to do this with most any toilet anyhow.
7. The toilet needs venting just like any other toilet; no problem here.
8. The toilet needs a fan for adequate venting, but takes very little power. This is a negative but I can handle this, I believe.
In summary, I only have one tank and I can now use it for grey water, I don't have to worry about dumping a 5 gal blue boy every few days, just a one gallon urine bottle.
It is a very different way of dealing with solid waste, but I think that the benefits will far outweigh the disadvantages for me. I know that new solutions have new problems. I am going to find out what those are.
Dan
Old 07-14-2012, 03:16 AM   #7
B_Boult's Avatar
1955 26' Cruiser/Overlander
Vancouver , British Columbia
Images: 21
I am sold
Hi Dan
I am also convinced a composting toilet is the way to go. I was going to plumb in a new toilet into my 1955 Overlander and after researching Airhead toilets I was sold on the idea of the composting toilet.
If opperated corectly it seems to me that it would be less hassle than dumping a black water tank and keeping it cleaned out. The composting system would be less smelly when dumping and simple for me to get used to. It is only me using my Airstream and if others do then they will have to learn to use the new system which is not hard. I keep my Airstream at the farm and if I can deal with horse and chicken poop which I compost for my gardens then I can deal with something far less messy or smelly after it is all composted and becomes dirt.
To me it seems like a simple system and environmentally better. The soil can go on my flower bed or into the outhouse. Yes we still maintain the original outhouse at the farm. Our grey water from the house goes into the flower beds beside the house and we use biodegradable soaps. The new cabin we are constructing out of one of the older buildings will also get a composting toilet. To put a septic field in would cost more.
My Airstream floor is going in and there will be no hole in it to a black water tank because there will not be one. Just attach composting toilet to the floor and done.
I have no problem with learning to use it and perfecting a good composting system. Emptying a backwater tank and letting someone else deal with my waste I am not to crazy about.
Also the fan for the toilet vent is a simple solar operated fan. The vent cap is the solar power system it can run by itself independent of your 12 volt power.
thanks
Brian
"You'll Never Walk Alone"
B_Boult is offline   Reply With Quote
Old 07-14-2012, 10:06 AM   #8
2004 25' Safari
1971 27' Overlander
Jourdanton , Texas
We are planning a Natures Head composting toilet for our Caravanner for the same reason as stated above: single holding tank now can be plumbed for gray water. Two drawbacks I see: not very feasible in a wet bath setup, and you have to allow sufficient room to open it up. Makes for a challenging arrangement in those shorter Airstreams.
Paula
pienjim is offline   Reply With Quote
Old 07-16-2012, 11:22 PM   #9
2008 23' International CCD
Denver , Colorado
Check in with Cece and Brenda at greenrvlive.com about the Nature's Head before you spend the money. We saw their setup a month ago and it was very nice. I'm going to check out this Airhead thing, though. See how it differs from N. Head.
Jim and Marsha
"Stream of Consciousness"
AIR #35886
JimmyT is offline   Reply With Quote
Old 07-16-2012, 11:34 PM   #10
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Jim & Marsha
I am going with the Airhead toilet because it fits the tight constraints of the Tradewind in terms of locating the toilet. The Natures Head needs another 2" of space behind the toilet for it to tilt back. I don't have this extra 2" of space. The Airshead toilet lifts straight up which works much better for me. Other than the space constraints, the toilets appear to be very similar.
Dan
Old 07-17-2012, 05:31 AM   #11
Gainesville , Florida
Curious? What would be the advantage over a portapotty? Pluses and minuses. Jim
avionstream is offline   Reply With Quote
Old 07-17-2012, 07:50 AM   #12
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Porta pottys have a distinct odor to them that I find nauseating. Porta pottys are not vented where Nature's Head and Airhead our which may eliminate significant odor
http://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Old 07-17-2012, 01:58 PM   #13
Splitrock's Avatar
Sioux Falls , South Dakota
bumperdumper
http://bumperdumper.com/bumper2.htm
Old 07-17-2012, 03:39 PM   #14
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Originally Posted by Splitrock View Post
A whole new dimension to the tailgate party. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
