Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 05-24-2005, 05:42 PM   #1
Zmod
Zmod's Avatar
Profile:
Access to shower control?
We have to replace our shower control on our 1978 AS but I can't see any way to access under the shower enclosure. Can anyone give me advice on how to do this? Thanks for your help.
John
Zmod is offline   Reply With Quote
Old 05-24-2005, 05:53 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Is your coach a center bath or rear bath?
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 05-24-2005, 06:17 PM   #3
Zmod
Zmod's Avatar
Profile:
It's a rear bath.
Old 05-24-2005, 09:18 PM   #4
Buttercup
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 25' Cruiser
VC Highlands , Nevada
Gotta pull the shower
We have the same problem. Shower mixer valve broke and pipe leaks.
I have instructions in our tech manual but it's for a 77 Overlander rear bath. Still should be about the same procedure.
I will be documenting once we get to that point. But for now it's removal of carpeting, etc...
Don't let the IBT Scuttle the WBCCI - Just Vote NO! Save Wally! Buttercup Web site Looking for a unit? Check out the SaveWally Unit Guide.
WBCCI # 17330, VAC Membership Chair, CAC Member
2008 Mouse count:
Buttercup -
Airtini -
Buttercup is offline   Reply With Quote
Old 05-25-2005, 07:39 AM   #5
PizzaChop
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Shower Control Removal
You don't have to remove everything (just a lot).
To access the control, you need to remove the horizontal ledge above the tub (to the left).
To do this (at least on my Overlander which is probably similar), you have to remove two screws that hold the end of it to the bath/bedroom wall. (You also have to remove the trim strip from the aluminum channel above and below the ledge piece so you can remove the rivets which connect everthing together.
The biggest frustration is having to remove the bedroom wall (double wall with pocket door inside) in order to remove those two screws on the end of the ledge piece. The aluminum channel is no big deal, although the plastic trim insert will probably crack up when you remove it (old and tired).
We replaced all of the plastic trim insert with linoleum strips cut to size...looks much better now.
Hopefully in your Sovereign, you have a closet or something just forward of the tub and you'll have easy access to the screws. (And won't have to remove a wall.)
(If your bath is totally different from mine, than disregard all advice. )
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 05-25-2005, 04:15 PM   #6
Buttercup
Buttercup's Avatar
1954 25' Cruiser
Pizza,
Looks great. I am going out today to start pulling ours. Lots of mouse droppings!
2008 Mouse count:
Buttercup -
Airtini -
Old 05-25-2005, 09:08 PM   #7
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Try cartridge repair?
Zmod-
We discovered owner manual in later model had detailed info on removal of cartridge, which otherwise appeared un-removable.. While our model not supported at local hardware or Home Depot/Lowes, there were commercial plumbing shops that were able to recognize and order replacement parts for it, and since plumbing in the connectors on all 4 sides in tight space is real challenge, it is worth second run at fixing the valve before replacing, unless the inlet and other pipes are also failed...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 05-26-2005, 01:19 AM   #8
Buttercup
Buttercup's Avatar
1954 25' Cruiser
We got the tob out!!!
We got the tub out but it cracked in one spot where it was accidentally glued to the vent pipe. Would have come out like butter if not for that. Found the cold water supply line had freeze burst.
pictures upcoming...
2008 Mouse count:
Buttercup -
Airtini -
Old 05-26-2005, 05:09 AM   #9
Zmod
Zmod's Avatar
Profile:
We got it fixed yesterday. The bottom panel in the small storage cabinet between the sink and tub came out. The access was tight but enough to replace the controls. Thanks to all for your help.
John
First shower in my 1975 Overlander !!! pjtaia Our Community 13 10-30-2002 08:52 AM
Shower head problems Pahaska Our Community 25 08-26-2002 11:43 AM
Shower head Pahaska 2003 International 0 08-24-2002 05:13 PM
Shower head Pahaska 2003 International CCD 0 08-24-2002 05:12 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 10:03 PM
