Old 04-26-2009, 03:09 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
ABS drain pipe to PVC connection
I am putting in a new sink and need to put in a new P Trap. Can I connect the PVC pipe to the old ABS pipe using PVC glue. I just need to make one connection with a 1 1/2" coupling to the old ABC drain line?
Don
adonh is offline   Reply With Quote
Old 04-26-2009, 03:27 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Install the new sink with plastic drain kits that you hand tighten. It will connect to the ABS pipe with a compression fitting. No glue required. You never know when you'll need to take it apart. A dropped ring or food clog can happen at any time. It's cheaper & easier than cutting it apart & buying new parts to glue back together.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 04-26-2009, 03:38 PM   #3
adonh's Avatar
1976 31' Sovereign
The part that I need to glue is an extension to the old 1/1/2" ABS drain that ran along the side of the trailer under the counter top. The extension will be be passed the P Trap with a 90 degree elbow to connect the new P Trap which will be connected with the fitting in the drain kit. So my concern was will the PVC glue make a strong and permanent bond to the ABS.
Don
Old 04-26-2009, 04:01 PM   #4
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Central , Illinois
choose glue carefully
Don, the answer to your question is mainly no, you cannot use PVC cement to join PVC to ABS. HOWEVER, their is a general purpose cement that can be used on PVC, ABS, and CPVC. It is made by Oatey, perhaps by other manufacturers as well. It should say right on the label that it can be used for those different types of plastic.
General purpose cement is not carried by all the big boxes and/or hardware stores, but it's not an obscure specialty item either. You may just have to look around a little.
One word of caution about the general purpose cement, it does dissolve the pipe a little more than PVC cement. With PVC cement you can insert the pipe into the coupling, give it 1/4 turn and it's done, you can walk away from it. With general purpose cement, you insert the pipe, give it 1/4 and then hold it in place for a minute or two, otherwise it might creep out on you.
Good luck with the project.
Laird
maccamper is offline   Reply With Quote
Old 04-26-2009, 04:23 PM   #5
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
You could use this kind of connector.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 04-27-2009, 07:56 AM   #6
adonh's Avatar
1976 31' Sovereign
Thanks everyone, I used the general purpose cement and it worked fine. I did connect some scrap pieces of ABS to PVC using regular PVC glue and it also seems to work. No way I could pull them apart.
Don
Can you mix black pipe with PVC? JimGolden Plumbing - Systems & Fixtures 19 07-22-2017 09:43 AM
ABS vs PVC Gkiesel Waste Systems, Tanks & Totes 5 07-11-2007 07:56 AM
Why black ABS pipe? Chuck Waste Systems, Tanks & Totes 2 03-25-2005 12:09 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 05:09 PM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 10:39 PM
