Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 01-08-2015, 04:23 PM   #1
1977 Argosy 24
okeechobee , Florida
'77 Argosy drain issue
new to airstream. when using my kitchen sink water backs up in shower. shower backs up also after a few minutes but drains after a while
bignip1989 is offline   Reply With Quote
Old 01-08-2015, 04:47 PM   #2
1978 Argosy 24
MooreHaven , Florida
Our 78 argosy 24 has this "vent" that i am not sure of its function but some of the posts answering my question seem to indicate that it may prevent siphoning such as you describe.Certainly not a definite answer but perhaps worth checking ours is an aft bathroom and this vent is located just inside the closet,perhaps yours has somehow become plugged or? mabe worth a look.
http://www.airforums.com/forums/f36/...nt-128945.html
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 01-08-2015, 05:21 PM   #3
1977 Argosy 24
thank you very much. ill check that now
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 08:42 PM
Another drain issue azfiredog300 Fresh Water Systems 4 03-18-2013 08:31 AM
Argosy 28 issue roderickm3 Argosy Motorhomes 4 02-12-2006 10:37 AM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
