Old 09-26-2010, 04:59 PM   #1
Royston, , B.C.
'75 Argosy trailer toilet 'flush water leak'
I've got a trailer that's been 'rode hard and put away wet!" I can't find a manufacturer's name on the toilet. It's got a two part foot pump and auxilliary shower head flush hose.
The leak is small - it's under the bowl at one of the threaded fittings - seems like three fittings in there. I've tried tightening/loosening using a 'stubby' box end but can only get one wrench in there. I want to use two wrenches so I don't split the aging copper pipe. Can't see any hold down nuts/bolts/clamps etc. The toilet sits on a 'pedestal' that's riveted together. Before I drill out the rivets etc to get access does anyone out there have any suggestions?
Derek
Derek Gardner is offline   Reply With Quote
Old 10-26-2010, 06:53 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
AS must have used the same plumber, my 2000 had same leak, plasitic fittings, over time they loosened, managed to separate by taking off hose and one at a time removed adapters and elbow, put a few wraps of teflon tape on each joint and put back using hand to tighten and final turn with plyers. They saved about two inches of tape on each joint.
Old 10-26-2010, 07:04 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Derek - you may want to post a picture of the toilet if you can.
Argosy Water Leak RBolton Leaks - Weatherstrips, Gaskets, Caulks & Sealants 20 11-08-2014 06:33 PM
Thetford flush valve leak 66Overlander Fresh Water Systems 17 04-10-2011 09:11 AM
toilet water line leak mlmarch Fresh Water Systems 0 07-27-2004 08:46 PM
Perma Flush Toilet COArgosy78 Sinks, Showers & Toilets 1 07-20-2004 11:12 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
