Old 08-17-2015, 07:29 PM   #1
1973 31' Sovereign
osotoos , bc
'74 Sovereign...object fell into blacktank
How do I explain....I was cleaning the rear bathroom, moved things around, didn't put them back. Later, I went into the bathroom with urgency, quickly planted myself onto the "throne" whilst hearing something fall. Well, when I flushed I heard another clunk. Looking around I saw a 3" Crystal ball a friend gave me was missing, the tripod it was on tipped over.
How do I get that out of there?
torchflame is offline   Reply With Quote
Old 08-17-2015, 07:40 PM   #2
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Ask the crystal ball to find out the answer.
Sounds like time to pull the toilet before it gets into the drain line. If you can see it use a shop vac to pick it up and out . Should have enough suction to hold it.
thehandyman is offline   Reply With Quote
Old 08-17-2015, 08:03 PM   #3
Mission , Texas
Or if you have a Sewer Solution, maybe you'll get lucky and it will come out and get rinsed off at the same time.
nrgtrakr is offline   Reply With Quote
Old 08-17-2015, 08:46 PM   #4
1979 23' Safari
Wayland , New York
Can you see it through the open toilet? Do you have small hands/arms. Maybe wrap your hand and arm in a garbage bag and see if you can reach in and get it. Pulling the toilet will give you a better reach.
If it was 3" it has very small chance of getting through the tank drain?
Old 08-17-2015, 08:54 PM   #5
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
www.nesa.org
Air No. 6427
Old 08-18-2015, 09:53 AM   #6
1973 31' Sovereign
osotoos , bc
Thanks for the advice. I forsee a good future, lol.
Old 08-18-2015, 09:56 AM   #7
1973 31' Sovereign
osotoos , bc
Oh geez. I'll turn off the water first and see what I see, although the tank had recently been drained ... then I will figure out how to remove the toilet. I am so not a handygirl. Damn.
Old 08-18-2015, 09:58 AM   #8
1973 31' Sovereign
osotoos , bc
What's a sewer solution?
Old 08-18-2015, 10:02 AM   #9
Mission , Texas
Sewer Solution
Old 08-18-2015, 10:12 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Your slinky is 4" diameter, right? So if you dump the black tank and rinse it out, the ball should come out. All you need is to dump into some netting that is small enough to catch the ball as it comes out but still lets water and dissolved solids pass through.
Whole lot easier than removing the toilet.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-18-2015, 06:09 PM   #11
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
Crystal Ball say...Recovery have $hitty outlook.
I'm sorry. I can't help myself.
StreamDog is offline   Reply With Quote
Old 08-18-2015, 07:08 PM   #12
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Where do you find a 4" slinky? Better measure yours..
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-18-2015, 07:10 PM   #13
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Now, that's funny, I don't care who you are!
Larry
sovereign
Older 13 Gallon Blacktank challenges gomotomoto Waste Systems, Tanks & Totes 15 10-20-2015 06:45 PM
My axles fell into place goransons Axles 0 03-19-2008 04:27 PM
Blacktank Flange Position/Opening? fotochop Waste Systems, Tanks & Totes 2 03-04-2008 01:26 PM
Step problem--bolt fell out--inaccessible Kistler Steps 4 08-24-2003 12:07 PM
Daughter fell out of the trailer... Safari Tim 1969 - 1973 Safari 12 07-22-2003 09:01 AM
