Old 01-03-2007, 01:41 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Question 71 Tradewind lavatory faucet
Can anyone tell me what is available in a replacement lavatory faucet with a diverter for a hand held shower head? I saw one at Campng World website for about $25 but no specs. I guess mostly plastic too as opposed to my original solid metal one. Should I just replace the guts on the old one? Pulling this faucet out is not a job I want to do twice. I don't know what kind of working condition the original is in.
Old 01-03-2007, 03:25 PM   #2
1976 25' Caravanner
Campton , New Hampshire
Chances are good that you can find replacement parts for your original faucet at a well stocked hardware or plumbing supply . Everything should come out the top , no need to remove faucet from sink unless damaged . Good luck.
ticki2 is offline   Reply With Quote
Old 01-03-2007, 05:43 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
Actually removing the faucet was secondary. The original project is removing, repairing and refinishing the lavarette. I had to pull the faucet to drill out some of the rivets and for the lavarette rebuild job anyway, hence the replace or rebuild dilema.
Old 01-03-2007, 05:50 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Marshall,
I'm rebuilding some faucts for another Forum member - see if this helps you any.
http://www.airforums.com/forum...der-28656.html
Good luck with your project.
Old 01-03-2007, 05:52 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I would try to rescue the Original one. Mine was corrodet to the point of no return ( i used to own a 71 Tradewind, btw.) I went and bought the plastic one from camping world, and it was, well, a plastic one from camping world....
It did work fine, though, and you can always chalk the plastic off to weight savings. Gas mileage, you now...
Uwe
www.area63productions.com
Old 01-03-2007, 06:25 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
I read Ganglin's rebuild post cited above. I'm impressed. Interested in a commision? By the way my faucet is a Streamline.
Old 01-04-2007, 06:45 AM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Marshall, Which faucet(s) are in need of rebuild. Your shower on the 71 should be a pull out single handle...?
Old 01-04-2007, 09:35 AM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
There is no separate shower faucet/ valve. It is a wet bathroom. There is a shower take off on the bathroom sink faucet which consists of a diverter valve similar to a shower/ tub valve. A flexible hand line comes off the top of the sink faucet. I can send you a photo if you send me your email address (I can't yet figure out to send photos as attachments on the forum). Thanks
Old 01-04-2007, 03:03 PM   #9
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
Camping world faucet
I installed that one in our 72 Tradewind. Works good. Easy to install.
72 tradewind is offline   Reply With Quote
Old 01-04-2007, 04:04 PM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Like This One
Is this it - if so it shouldn't be to bad to rebuild. The telephone head has one gasket at the the hose connection and one large O ring in the head - just like our 71 Overlander. The faucet likely has bad stem washers and O rings.
Old 01-04-2007, 04:50 PM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
That's the pupppy.
Old 01-18-2007, 06:21 PM   #12
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Done Yet....
Marshall,
Do you have that puppy rebuilt yet....
Old 01-18-2007, 06:33 PM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
Good news/ bad news
I went to a plumbing store in Albuquerque a few days ago. One guy looked at the faucet, then looks at me, then looks at the faucet and then calls someone else. They don't think new stems are available. They were not sure if the O rings they have were the right thickness, but said the ones in the stem looked OK. They did have the gaskets on the end of the stem. They also did not have the parts I need for the trap but sold me a rubber tube seal in case I have to cut it. I'm not sure when I will get it put back together and I still have to finish repairing the sink/counter. I also won't have water in the system until after last frost in April so I wonder what other surprises are in store for me then.
Old 01-19-2007, 07:39 PM   #14
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Mostly Good News...
I'd replace the O rings while it's apart. Take one off and go to Lowe's - they have a board in the plumbing department with all the O rings mounted on it. You can compare and find the correct ones. Don't forget the tube of plumbers gasket lube to rub them down with. The stem nuts under the handles should/may have a thin plastic ring gasket - salvage them if you can - if not you'll only find them in a hardware/plumbing store. Lowe's and Home Depot don't carry them.
Good luck to you.....
'61 Tradewind lee_jachter 1959-69 Tradewind 11 04-20-2010 01:47 AM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
'67 Tradewind: Where is my Univolt ??? Mike Rhodes Electrical - Systems, Generators, Batteries & Solar 5 07-21-2002 06:03 PM
tradewind holding tank McGill Waste Systems, Tanks & Totes 3 06-22-2002 09:28 AM
