Old 08-03-2009, 02:16 PM   #1
tdoescher's Avatar
1969 31' Sovereign
Madison , Wisconsin
69 Sovereign - Shower Curtain Rod or ???
69 Sovereign - Shower Curtain Rod - There is no track or shower curtain rod in my airstream- I assuming someone took it at one time. What has other users used for a shower rod? I am looking for ideas since the ceiling has a curve in a little stumped on what I can hang to fit a shower curtain?? Any ideas or photos of what you put in your airstream for a rod would be helpful. Thanks Todd
tdoescher is offline   Reply With Quote
Old 08-03-2009, 02:30 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
If your Sovereign is anything like mine, you had a bi-folding shower door attached to the wall behind your tub. The previous owners removed mine prior to me buying my Sovereign. Fortunately, I was recently able to pick up a used door from Minno.
At this point you have a few options. Install a shower rod from the wall to above the cabinet. Install a bendable shower track from the wall following the contour of the tub (an L shape), Or, get a used shower door like me.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-21-2009, 10:21 PM   #3
1969 27' Overlander
Lehi , Utah
the shower curtain in our 69 Overlander Is Gold and Gross. has any one replaced this with something else?
Clay C
ClayC is offline   Reply With Quote
Old 08-22-2009, 03:08 AM   #4
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hello... Just take down the old one and use it as a pattern on any shower curtain you chose..
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 26 04-02-2017 09:10 PM
Shower Curtain Rod '68 Safari? gc24 1966 - 1968 Safari 3 09-09-2008 04:19 PM
Shower curtian Rod suggestions for 68 Sovereign? tvadman1963 Sinks, Showers & Toilets 2 03-30-2007 11:49 AM
Shower curtain Waynon 1984 -1986 Excella 5 09-09-2006 10:03 AM
Hott Rod & Lightnin' Rod femuse Water Heaters, Filters & Pumps 6 09-22-2003 11:46 AM
