Old 06-11-2015, 01:32 PM   #1
Champaign , Illinois
68 overlander toilet
I'm having trouble removing my 68 overlander toilet....when I go to remove the flange bolts they just spin. Should I saw saw the bolts under the toilet? Thx in advance for all the help.
Cmcc_7 is offline   Reply With Quote
Old 06-13-2015, 04:36 AM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Chances are the ears on the flange bolts have rusted, or the flange itself has rusted. Taking apart one of our old trailers can be a real chore. And the tight spaces make it even more of a chore. I don't know how your 68 was built. I do know the bathroom was significantly redesigned compared to my 66.
Some of us disassemble our old trailers with the idea of replacing the major appliances. If that is the intent, then more demolition of the old toilet may be in order.
If you are trying to save the old toilet, you may have to spend a lot of time carefully grinding the nut off the old bolt if you can get any kind of tool in there. I had access to the old toilet from the rear "one stop set up" compartment. My 66 was very rusty. I had to destroy the bolts to get the toilet out. My trailer had a heavy porclein toilet with a heavy iron connection pipe toilet to flange. See the photo below.
My trailer had this tiny, shallow black tank that was cracked on top. The toilet flange was molded into the tank. I don't believe this design would ever work very well for draining sewage. A 3" high black water tank is no good. See photo.
David
Name:	1311 Plumbing City Water Connection.jpg
ID:	240552   Click image for larger version
Name:	1311 Tank Black Removed.jpg
dbj216 is online now   Reply With Quote
Old 06-14-2015, 07:11 PM   #3
Thx for the info. I'm gonna take the sawsall to it...wish me luck
Old 06-14-2015, 08:00 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
The recip-saw should do it. I cut the bolts on mine off with a dremel and a cut off wheel. It is a tight space. Note that the plastic insert molding that hides the rivet lines in a 68 bathroom is not available anywhere. I spent a year trying to find some with no luck. Take care with it if you remove parts from the bathroom as you will need to reuse it.
Once the toilet is off, the closet flange unscrews from a short pipe that connects it to the threaded flange on top of the black tank.
If I remember I used a big punch and hammer to get it started. The floor in my 68 was rotten so the screws holding the flange down were gone, if your floor is good then you will need to remove those first.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Toilet seal for vintage toilet thinktankair Waste Systems, Tanks & Totes 0 06-09-2014 12:37 AM
Changing a toilet to a standard toilet bamamama Waste Systems, Tanks & Totes 8 07-21-2012 06:12 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Rebuilding '68 Overlander Toilet Uberlanders Sinks, Showers & Toilets 5 04-17-2005 09:37 PM
