Old 08-22-2012, 02:27 PM   #1
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
'66 Toilet leak - Slide O Matic
Need help with our toilet in the 66 Tradewind. When we pressurize the water system there is a small leak in the bottom of a brass fitting. This is the brass fitting that sits on top of the "Slide O Matic" top plate. When you press the foot pedal down the plate slides out, rotating a screw in the bottom of this big brass fitting to send water to the bowl. Its dripping at the arrow in the photo.
Here is a pic of our toilet setup, the slide o matic and the big brass thing thats leaking from the bottom. It appears we need to change out the big brass fitting, is this piece still available?
Name:	brass fitting.jpg
ID:	166439   Click image for larger version
Happy Trails!
Jezibels is offline   Reply With Quote
