Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 03-14-2007, 12:55 AM   #1
FreshAir
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
'66 rear bath toilet
I am about to replace the original toilet into my '66 Tradewind rear bath AS. I have replaced the floor and black tank. Before I had removed the toilet I noticed that the top rim of the bowl did not meet the fiberglass bench it sits under by about 3/4 of an inch. The bench would flex down to the toilet when a person sat on it. I thought it may have been from a sagging floor. The floor has been now replaced but the toilet is still below the bench. I tried shimming the toilet up but after 1/2" the floor screw in-flange (to black tank) loses it's connection. I was thinking maybe there was originally a rubber collar or bumper that was supposed to fill that gap from the top of the toilet to the underside of the bench. Anyone know if that is true or any suggestions to correct the problem I have?
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
Moonrise - Sunset
October 13, 2008
1966 Trade Wind
455 cid
Old 04-01-2007, 09:47 AM   #2
dibAL
Profile:  1966 22' Safari
north stonington , Connecticut
'66 rear bath toilet seat sag
My '66 had a shim between the top of the bowl and the bottom of the bench. The interior was bridged with a plastic trim ring. The somewhat delaminated shim consisted of two pieces of 1/2 plywood cut to the bowl dimensions. It was anchored by the seat bolts extending through the bench. I'm in the process of replacing toilet; should this be necessary again, I will probably fabricate something out of plastic (though the plywood did last 40 years). Hope this helps, mike
dibAL is offline   Reply With Quote
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 08:45 PM
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 09:52 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 07:46 AM
Moving the Rear Bath Forward? jabra General Interior Topics 2 10-18-2002 06:09 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 10:00 AM
