Old 05-20-2010, 06:59 PM   #1
Johnsonbrg , Pennsylvania
'66 Overlander...what toilet do you use?
I just found out after replacing a ton of plumbing that my toilet is leaking between the bowl and the foot mech. I did a little forum searching and see that a lot of folks just replace the original wit an aqua magic V. If anyone has done this conversion did you use the short or tall version with foot or hand flush? I'm assuming the short with a foot with either a homemade spacer, or I see there's one available that lifts it up 2-1/2 inches. I figure before I just start ordering parts maybe someone out there has done this and could grace me with any suggestions as to what to buy and tips to install! Thanks in advance!! Randy Lindberg
rlindberg is offline   Reply With Quote
Old 05-20-2010, 09:14 PM   #2
rideair's Avatar
Randy,
Let me know if you decide to replace the unit, I'd be interested in taking it off your hands.
Paul Waddell
rideair is offline   Reply With Quote
Old 05-22-2010, 04:12 PM   #3
1971 18' Caravel
Fowlerville , Michigan
Paul, I may have one for you. Are you looking for specific parts or the entire toilet and valve? (Are they repairable)
giffy58 is offline   Reply With Quote
Old 05-23-2010, 02:01 PM   #4
Bump
Old 05-24-2010, 06:19 AM   #5
rideair's Avatar
Randy,
I've heard they can be repaired given enough time and energy. The one in my 66 Safari is cracked (PO glued no leaks) and is still working and I like to have a complete backup.
Paul Waddell
Need new toilet for 72 Overlander krazeekalvin Sinks, Showers & Toilets 2 11-30-2009 09:00 AM
77 Overlander toilet replacement 77Overlander Sinks, Showers & Toilets 5 11-04-2009 11:10 PM
Toilet Replacement for 66 Overlander wolf den 1965 - 1969 Overlander 3 08-11-2008 11:04 AM
'66 overlander sans toilet mike p. Plumbing - Systems & Fixtures 5 03-15-2008 07:50 PM
Best new toilet for 70 overlander? jesus mike Sinks, Showers & Toilets 5 11-16-2007 09:24 PM
