Old 05-04-2010, 05:26 PM   #1
1964 22' Safari
Ruston , Louisiana
64 safari bathroom sink access
Folks,
I am new to this so please bear with me. I am restoring a 64 Safari and would like to replace the faucets on the bathroom sink and shower. My question, which has probably been asked before is how the heck do I gain access to the plumbing / faucets under the sink. I can't see how to get the sink out.
Thanks in advance,
La Safari 64 is offline   Reply With Quote
Old 05-04-2010, 06:56 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Welcome to the forum,you should be able to get the right answers here. Doesn`t the 64 have a trunk ? If so you should be able to get to it from there. Dave
easyride is offline   Reply With Quote
Old 05-04-2010, 09:05 PM   #3
VIKING's Avatar
Boulder Creek , California
Hi La Safari 64,
Welcome to the forum, and the '64 Safari club! Well, not really a club, just some fellow owners. It's really easy to get to the faucet connections. You just lie on your back in the tub, with your feet sticking up in the air, and look at the bottom of the sink surround. (no, really. I mean it.) There's a hole under there for you to get to the pipes and fittings. Removing the sink is another matter altogether. I would have to go look at mine to refresh my memory.
It helps to have small arms and hands, and a flashlight on the end of your nose to be able to reach into the hole and still see what you are working on. And don't think you are going to actually SEE the fittings, you are still going to be working by braille to some extent.
I recommend having a small, young person with strong hands do this part for you.
Are you needing to remove the sink for another reason, or just to gain access to the faucets?
Take a look at my long out-dated blog for some familiar looking pictures.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 05-05-2010, 05:25 AM   #4
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
It's starting to come back to me too. There are rivets holding the sink to the tub. You get to those via the rear access door. The sink is also held along it's back to the back wall. The tub trim has to be removed to find those rivets. The very top of the sink also comes loose from the bottom of the sink, but I think you have to remove the sink first. Not sure that this covers all of it, but removing the tub and the sink took me all day, that I do remember.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 05-05-2010, 08:01 PM   #5
VIKING's Avatar
Since I am able to get a view of this that not many are able to, maybe this will help you find those hard-to-get-at fasteners.
Looking closely at the hole in my sink shroud I see that it's cut a little rough, which leads me to think it may have been an aftermarket hole. Perhaps yours needs one of these handy circular devices which allow you to reach right through solid matter!
Best to you,
Rich the Viking
Name:	'64 safari sink 001.jpg
ID:	101865   Click image for larger version
Name:	'64 safari sink 002.jpg
Name:	'64 safari sink 003.jpg
ID:	101867   Click image for larger version
Name:	'64 safari sink 005.jpg
Bathrooom sink faucet access 1964 Safari64 Sinks, Showers & Toilets 0 11-03-2009 04:51 PM
Access to bathroom plumbing maxi28 Plumbing - Systems & Fixtures 11 06-04-2009 12:05 PM
bathroom sink Squid All Argosy Trailers 15 02-05-2009 07:43 PM
Bathroom Sink grovelander Cabinets, Counter Tops & Furnishings 2 10-20-2007 06:40 PM
Bathroom sink problem 71 Safari Larry71 Sinks, Showers & Toilets 8 06-04-2005 05:47 PM
