Old 01-11-2011, 10:54 AM   #1
1966 20' Globetrotter
1985 25' Sovereign
johnsoncity , Tennessee
64 bath sink sprayer
have leaky sprayer that needs to be removed since we don't use it. how do I get the sprayer hose out and stopped - do I need to remove sink? If so, how do you get the sink out?
donh1 is offline   Reply With Quote
Old 01-11-2011, 01:21 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You should be able to get to it from inside the rear compartment. Some flexibility on your part may be required. You can probably put a plug or cap where the line for the sprayer comes out, and you shouldn't have to take the sink out. If the sink isn't one of those molded-to-the-counter ones, it may be easier to get to, though. Just a dozen or so 5/16" or 3/8" clamp bolts and disconnect the P trap.
Old 01-11-2011, 02:05 PM   #3
NicheVintage's Avatar
1965 26' Overlander
Scottsdale , Southwest
Images: 34
We were able to access our for replacement under the sink. My husband got down in the tub and could reach it from there. It is a bear to get to. You should be able to cap it off. I think most are run off the cold water supply line. Good luck.
NicheVintage is offline   Reply With Quote
Old 01-11-2011, 02:13 PM   #4
1985 25' Sovereign
Thanks but getting down in the tub and looking up under the sink; there is no access hole or anything. Did you have an opening under the sink?
Old 01-11-2011, 02:18 PM   #5
1965 26' Overlander
Images: 34
On ours there is an opening in the back.
Old 01-11-2011, 05:11 PM   #6
VIKING's Avatar
Boulder Creek , California
My faucet had the shower riser attached to the top of the faucet. It wouldn't be necessary to get under the sink on mine, though there is an access hole.
I found out that not all '64s had this hole. I can remove the faucet and disconnect all of the under-sink plumbing from inside there with a lot of contorting and straining. This is where I learned "blind-plumbing".
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
the BUFF kitchen sink tvanwave Sinks, Showers & Toilets 10 01-17-2011 07:47 PM
