Old 02-05-2007, 10:25 AM   #1
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
'64-65 toilet replacements...
I'd like to get a thread going here to see what others have done when replacing their original under-mount toilets in the 64/65 models...
There has to be some really creative ideas out there for adapting newer toilets so that I don't have to 'reinvent the wheel' on this one...
Doug
59er is offline   Reply With Quote
Old 02-05-2007, 11:11 AM   #2
I too am interested in this one. Are there such things as elongated bowl RV toilets?
toddster is offline   Reply With Quote
Old 02-05-2007, 12:24 PM   #3
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
just for grins...this is where I'm starting from...
(hopefully, picture attached?)
Doug
Old 02-05-2007, 12:25 PM   #4
S C Streamer's Avatar
1964 17' Bambi II
Santa Cruz , California
Images: 13
Count me in also...
I'd like to find a modern toilet with a vintage look...
like this old Townsend...
Does anyone make something like this?
Mark
1964 17' Bambi II
2005 Dodge 2500 PowerWagon -5.7 Hemi
WBCCI #4207
AIR #11485
"you don't need a weatherman to know which way the wind blows" ~bob dylan
S C Streamer is offline   Reply With Quote
Old 02-05-2007, 12:35 PM   #5
1964 17' Bambi II
Images: 13
I can't even grin when I look at what I'm starting with...
cheap and ugly.
Mark
1964 17' Bambi II
WBCCI #4207
AIR #11485
Old 02-05-2007, 12:38 PM   #6
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
that green is suprisingly stylish though....and at least is looks clean?
Doug
Old 02-05-2007, 12:48 PM   #7
1964 17' Bambi II
Images: 13
That's because the rat (four legged kind) that used to live in the trailer, went everywhere else but the toilet.
Mark
1964 17' Bambi II
WBCCI #4207
AIR #11485
Old 02-05-2007, 02:15 PM   #8
1964 17' Bambi II
Images: 13
Can I ansewer my own question?...
Attachment 31854
After searching around I came up with this...
SeaLand Traveler Lite 110 @ Traveler Lite, about $145.00
Mark
1964 17' Bambi II
WBCCI #4207
AIR #11485
Old 02-05-2007, 02:32 PM   #9
GreatPumpkin's Avatar
Colville , Washington
Images: 70
I've got a Sealand (Mansfield) Traveler 510. The P.O. had "installed" it with a "custom" cut board to raise the height to meet the bench height. I correctly installed it using a riser. It required trimming the bench slightly to let the bowl thru, but seems to fit just right.
The Traveler Lite has also been recommended by many other forum members here.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 02-05-2007, 03:25 PM   #10
Jacob D.'s Avatar
1964 26' Overlander
Alameda , California
I cut the bench off (broke it taking it out, and once I'd seen the underside of the bench rim decided there was no way I was using something as hard to keep clean as that) and will use a standard toilet, probably a Sealand Traveler, when I replace it. The bench looks like a good idea - hey, hide the toilet, kind of nice - but hygiene-wise it seems like a nightmare.
To re-trim the bathtub, I plan on replacing the whole lower front panel in a continous section going around the bath and under where the sink goes, so hopefully it'll look like it was designed that way, rather than being cut up. If I could figure a way to build something that would cover the toilet while being easily removable, I'd do it, but I don't have any ideas offhand.
Jacob D. is offline   Reply With Quote
Old 02-06-2007, 10:16 PM   #11
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Patch piece needed
Does anyone have a piece of the toilet bench they removed left over?
I need a flat piece about 8"x4" to patch a hole PO made in my 64.
Thanks, Safari64
Safari64 is offline   Reply With Quote
Old 02-07-2007, 01:56 PM   #12
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
you could make an easy patch by wetting a piece of glass cloth with resin, over wax paper....on something flat?
once it dries, just glass it into the cut out area.
Doug
Old 02-07-2007, 03:22 PM   #13
Safari64's Avatar
1964 22' Safari
Thanks Doug,
That's what I'll do if I can't find a piece. I was hoping to get a piece of an old 64 bench, mostly for color matching.
Safari64
Old 02-07-2007, 06:58 PM   #14
Jacob D.'s Avatar
1964 26' Overlander
Were they all the same colour? Mine is a sort of horrible green. Not avocado (I'd prefer that) but a little lighter. But others I've seen looked beige or tan.
Old 02-07-2007, 07:17 PM   #15
1964 24' Tradewind
Peoria , Arizona
Here's a thought...
Thanks, Safari64
Safari64,
I am getting ready to extend my tub and cut back the toilet bench area of my '64 Tradewind. It is a beigeish color if you want it, maybe we can work that out...PM me.
Anyway, to add to this discussion - here's something cool to think of if you have the $$$$ for it. I wanted to have a toilet setup that mimicks more closely that of a system in a house, so I came across Vacuflush Technology. It's made by Dometic and there are three parts: Toilet which goes to a Vaccum Generator, which drains to your black tank. What is sooooo cool is that the three components are connected to each other by sanitation grade hoses so you can put the toilet anywhere you want! No odors, and the vaccum generator pump acts like a macerater and keeps your black tank from getting clogged with "solids." I spoke to a local rep in my area and he said the basic system (toilet and generator) would cost around $1200. Before you laugh into oblivion, remember that with this setup there ar NO limitations to where you put your components and odors and clogs are virtually eliminated. Here's the link if interested:
http://www.dometicsanitation.com/vf.asp
They even have a cool flash demo of how the system works. Thanks to all of you out there for the awesome advice - this is my first time putting my two cents in...
nbk3ad2 is offline   Reply With Quote
Old 02-13-2007, 02:12 PM   #16
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
If he doesn't take the piece, please let me know what you have...
Doug
Old 02-15-2007, 09:46 PM   #17
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I have a vacuflush in my boat. I bought the boat new in 1997. It has worked well. I have had zero issues with the system. I could not say that in my previous 1989 boat with a electric pump type system. I can not speak to cost since it came with the boat.
>>>>>>>>>>>>>>>Action
Old 02-27-2007, 09:40 AM   #18
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
Any of you have any pictures of how you've retro-fit a new style toilet into the 'bench'?
Doug
Old 03-02-2007, 09:20 AM   #19
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
nobody?
Doug
Old 07-25-2007, 09:19 AM   #20
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
here's what I ended up doing.
I rebuilt the missing part of the 'shelf' from a damaged tub/shower unit that fell off of a truck on the hwy.
this is the 'before' and 'during' shots. 'after' is soon to follow...
ID:	41935   Click image for larger version
Doug
Toilet Replacement 3Ms75Argosy Sinks, Showers & Toilets 22 02-18-2007 07:51 PM
Rear toilet platform rotten, now what?? MontanaArgy Cabinets, Counter Tops & Furnishings 9 08-14-2005 06:46 AM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 10:59 AM
