Old 09-01-2014, 03:35 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
'06 Safari FB Water leak from Shower Drain
So on our last rally we detected water coming from under my trailer as my wife was taking a nice shower. I took off the end panel in the bedroom that is outside of the shower wall to take a look. Unfortunately the leak isn't near the J drain near the outer wall but at the other side of the shower as this 3 ft. or so of black PVC pipe makes a connection as I'm guessing is headed to the grey eater tank underneath. So the question is to those who know- what is the best way to get to that side of the trailer to repair. It's too far to reach from the end wall panel. There is a top panel in the closet that may be above this area but it's about a foot long and about 6 inches wide. Hopefully this can be repaired without removal of the shower, which I'm not up to that task of tearing half the trailer apart, unless...
Photo taken shows place PVC pipe and you can see the wet floor under. At the far end at that fitting is where the water is leaking from. Any wisdom on how to proceed would help. Thanks
Name:	Safari shower.jpg
RichHog is online now   Reply With Quote
Shower drain leak - 2006 International CCD tanniwells Sinks, Showers & Toilets 4 04-18-2016 10:14 AM
Fresh Water low drain leak SilverEagle6 On The Road... 9 07-14-2014 11:30 PM
HELP! Water leak In 2005 Safari 28W Coming from behind shower? Shirley C Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 12-30-2012 06:51 PM
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 06:45 PM
Water in Shower Drain?? 76 Argosy. THEPILL Waste Systems, Tanks & Totes 2 01-02-2010 09:27 PM
