Old 02-22-2010, 12:27 PM   #1
rochar3's Avatar
2003 31' Classic
Valparaiso , Indiana
03 Airstream toilet
Help:
My toilet has stopped holding water and I have done just about everything. Silicone, clean flap etc, etc.
Any other suggestions?
Bob-air # 657
I can win any argument on any subject. People know this and steer away from me at parties. Often as a sign of their respect, they don't even invite me.
rochar3 is offline   Reply With Quote
Old 02-22-2010, 02:11 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Depending on the model of your toilet, there may be a rubber gasket on the underside of the hole where the flapper seats itself. In 7 years that could have easily gone bad. I suppose the spring that holds it closed could also have weakened. Check if there's a rebuild kit for your toilet make and model - the manufacturer's website might be a logical place to start. You'll surely end up pulling out the throne and rebuilding it - so super clean your black tank first or be prepared for major WHEWIE when you unbolt it.
Of course if you're one of those millionaire Airstreamers you could just replace it with a new one that washes and blow dries your nether parts!
Your Avatar says you have a Classic - I'm assuming a porcelain bowl. If it's plastic it's probably time for a new one.
Paula
Old 02-22-2010, 03:38 PM   #3
2010 25' FB Flying Cloud
Davenport , Iowa
When I had my "98" I needed a complete overhaul of the toilet, and there wasn't much difference between the overhaul and a new toilet. I opted for the new toilet and got the higher one. As one gets older, it makes the getting on and off easier. Plus I had had a hip replacement.
mike
Airtandem is online now   Reply With Quote
Old 02-22-2010, 05:48 PM   #4
bertro's Avatar
1971 23' Safari
Groveport , Ohio
If it is a plastic toilet sometimes some paper gets in the groove of the rubber gasket on mine and prevents the plastic sealing plate from seating all the way. I take peice of a plastic fork and clean the groove out and I'm back in saddle again. Robert
bertro is offline   Reply With Quote
Old 02-22-2010, 08:06 PM   #5
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
This is from the manual
CAUTION: When you dump the bowl of the toilet make sure all paper and solids have cleared the
slide mechanism before you allow it to close. Failure to do so can cause the groove for the slide to become
jammed and the slide will no longer close completely.
If the problem should occur a small nail or bent clothes hanger can be used to "pick" the material out of the
groove.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 02-23-2010, 06:13 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
, Put in a 1/2 cup of veggie oil, let it sit for awhile, work it, work it, repeat if necessary. Clean and flush well. Worked on our "classic".
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 02-23-2010, 09:09 AM   #7
1977 Argosy 24
Milltown , Wisconsin
The veggie oil if drank, will get you to clean & flush well also.
ventport is offline   Reply With Quote
1962 Airstream Bambi w/Toilet and Shower Very Rare Find eBay Watch Airstreams on eBay 0 08-01-2009 09:50 AM
1962 Airstream Bambi w/Toilet and Shower Very Rare Find eBay Watch Airstreams on eBay 0 07-11-2009 08:20 PM
New toilet or not? RandyG Sinks, Showers & Toilets 2 02-19-2009 07:39 PM
Toilet dmac On The Road... 1 06-27-2003 04:28 PM
Toilet dmac 2001 Safari 4 12-11-2002 07:29 PM
