Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 04-19-2008, 04:26 PM   #1
henw
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere , Florida
Zinc anode
It really works. Last summer, after 6 mths use, I flushed out my water heater. I was surprised a the mineral sediments that had already built up. I bought an anode bar that fits right on the drain plug. This time all the sediment was bound to that bar. It brushed right off with a wire brush. Should be good for another year.
Tom
2007 28' Int CCD.
2008 F 250 6.4L Diesel.
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
henw is offline   Reply With Quote
Old 04-19-2008, 04:40 PM   #2
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Tom
Tom,
The anode may be a bad idea since you have an aluminum tank. That residue maybe partly your tank.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 04-19-2008, 04:51 PM   #3
campcollector
campcollector's Avatar
Profile:  2003 19' Bambi
Lincoln City , Oregon
Images: 21
Even though the tank may be aluminum. The galvanic index of a zink or better yet a magnesuim anode is higher. In theory since it is higher it should sacrifice before the aluminum.
"No good dent goes unpunished."
campcollector is offline   Reply With Quote
Old 04-19-2008, 05:12 PM   #4
markdoane
Profile:  , Minnesota
Images: 59
After a little searching, I've found that you can buy either zinc or magnesium anodes.
Those of us with a Suburban water heaters can even choose an aluminum anode, so we can be at least partially true to our aluminum roots. Our tanks may not be aluminum, but our anodes are!
Non-contributing deadbeat.
Old 04-19-2008, 05:22 PM   #5
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
If I'm not incorrect (Don, that's a setup... ) I've read somewhere about the OEM Atwood WH -- that using a sacrificial zinc voids the warranty and can damage the WH.
This couldn't be the mini black hole people are worried about?
Old 04-19-2008, 05:50 PM   #6
2airishuman
2airishuman's Avatar
Profile:
anode smanode...
Anode Rod...c post 4n5
_____________________________________________
Question 4
Are all water heaters equipped with an Anode Rod? What is its function? When should it be changed?
Answer:
Only Suburban water heaters feature an anode rod.
The anode equalizes aggressive water action, providing cathodic protection for the tank.
It is a very important factor in tank life and should only be removed for inspection, draining or replacement.
It is removeable using a 1-1/16" socket.
All Suburban water heaters are protected by a magnesium or aluminum anode to prolong the life of the tank.
Under normal use, the anode rod will deteriorate.
Because of this, we recommend it be replaced annually or when consumption or weight loss of the rod is greater than 75%.
Note: Water with high levels of iron and/or sulfate will increase the rate of deterioration.
To extend anode life, drain water from tank whenever the RV is not being used.
Avoid any extended time of non-use with water in the tank.
from the home office is warmnwater, washingfeelsgood, usa...
ATWOOD CLAD TANK
The Atwood water heater tank is constructed of a core of high strength aluminum.
The interior of the tank consists of a 15% thickness of type 7072 aluminum (pure aluminum and zinc)
that is fused to the core during the rolling process.
This material protects the tank from the affects of heavy metals and salts found in waters throughout the country.
It is anodic to these heavy metals and acts much like an anode in a steel glass lined tank except it will last much longer.
There is also no need to replace an anode on a yearly basis.
Flushing the tank on a regular basis has been found to be helpful in insuring the best performance of your water hater and adding to the useful life of the tank.
For flushing instructions see your owners manual or contact Atwood for a copy of our recommended procedures.
________________________________________________
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 04-19-2008, 08:50 PM   #7
markdoane
Images: 59
I have a Suburban water heater, so I can use any anode that is anodic to the steel jacket.
As far as the Atwood aluminum/zinc clad tank, I suppose the cladding provides some anodic protection, which is probably long enough to make it through the warranty period.
After that, I would use a magnesium anode. It's easy to check if it is effective, just check it for pitting after 6 months. If it's pitted, its protecting the tank. If it's not, throw it away.
Old 04-19-2008, 10:11 PM   #8
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Don't know how old your Atwood water heaters are, but it IS TRUE that the addition of ANY device like an anode, or auxiliary electric heating element (Hott Rodd) WILL VOID YOUR WARRANTY.
This is not just a CYA exercise, as the tanks of the Atwoods do not like anodes, or the factory would put them there in the first place....like Suburban does!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Anode Rod SilverCabin Water Heaters, Filters & Pumps 8 02-04-2008 09:54 PM
Atwood Bowen anode rod? Moonshot Water Heaters, Filters & Pumps 3 11-11-2003 08:37 AM
Checking the Anode Rod... ALANSD Water Heaters, Filters & Pumps 1 05-08-2002 09:23 AM
