Old 03-09-2014, 07:30 PM   #1
1969 27' Overlander
Boise , Idaho
Wiring my new Shurflo
I bought a 69 Overlander in half-way through demolition condition. I am now ready to install a ShurFlo water pump, in the original location, front curbside next to the fresh water tank. Exiting the interior panel at this location are six wires. Four of them are 14 or 16 gauge, and I am nearly certian those four originally served the water level sensor. There are two 12 ga. conductors, one red, one white. BTW, I did not rewire this trailer, as the electrical system aactually worked almost perfectly, once I installed a new converter.
So, I have red and white conductors. The ShurFlo has black and red conductors. The red attaches to the pump at the valve/pump end of the body, the black connects at the motor end of the body. A third red conductor runs from motor end to valve end, is attached at both ends.
How do you suppose I wire this?
Jamespio is offline   Reply With Quote
Old 03-09-2014, 07:50 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
On the pump, red is +, and black is ground.
Turn on the switch for the pump, probably in the control panel over the couch, and see which wire has power. Use a test light. Make sure that wire does not have power when the pump switch is off, then connect it to the red wire on the pump. Find a ground, and connect it. Ignore the other wires for now, you'll figure out what they go to later in your project. Just don't bury them, you may need them.
Old 03-09-2014, 11:19 PM   #3
1969 27' Overlander
Boise , Idaho
Who the heck uses black for a ground? Is that maybe a 12V thing? My wiring experience is limited to 110 and 220V.
Thanks.
Old 03-10-2014, 12:10 AM   #4
1974 Argosy 20
Kooskia , Idaho
The #12 wires in the trailer: Airstream uses white for all of the - (negative) wires and various colors for the +. In this case your red trailer wire is the +.
The pump black and red wires wold be black as - (negative) and red as +
So red to red and black to white.
Wiring schematic: 1969 Overland. edglenn Electrical - Systems, Generators, Batteries & Solar 3 09-15-2011 07:17 AM
Brake Controller Wiring Harness wlanford Brakes & Brake Controllers 3 08-01-2011 12:14 PM
30 amp/120v Wiring question... Trex Batteries, Univolts, Converters & Inverters 13 07-26-2011 07:47 PM
Wiring Schematic for '68 Ambassador 29? Silver Suckr Electrical - Systems, Generators, Batteries & Solar 1 07-23-2011 11:13 AM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
