Old 04-04-2014, 10:27 PM   #1
sfalvo's Avatar
1977 25' Tradewind
Strongsville , Ohio
Send a message via Skype™ to sfalvo
Will my water pumped get damaged?
If I am drawing water out of my freshwater holding tank and I run it dry to clear out all the water with the pump running but no water coming out, will it cause damage to the pump.
What about starting the pump before turning the water on, will this cause damage to the pump?
Spencer
Sent from my SM-N900T using Airstream Forums mobile app
sfalvo is offline   Reply With Quote
Old 04-04-2014, 10:32 PM   #2
Spencer
What make water pump?
Old 04-04-2014, 10:56 PM   #3
aftermath's Avatar
Spokane , Washington
No, it shouldn't harm the pump. But then......what kind of pump do you have and how long did you run it dry? As part of my winterizing regimen I run the pump dry for a couple of minutes and have never had a problem.
As a matter of fact on an older tent trailer I had I forgot to turn the pump off when I was breaking camp and I opened the fresh water spigot on my way out of the campsite. A few hours later as I was pulling into the driveway I heard the pump running. It had run dry for the entire trip home. No damage, no problems for the next few years.
I wouldn't worry about it.
aftermath is offline   Reply With Quote
Old 04-04-2014, 11:05 PM   #4
sfalvo's Avatar
1977 25' Tradewind
Strongsville , Ohio
Okay, I didn't know if you would have the same outcome as you would running an outboard boat motor without water going through it.
Thanks for the reply.
Old 04-05-2014, 12:31 AM   #5
1974 Argosy 20
Kooskia , Idaho
I have run water pumps dry fairly often, and sometimes for over an hour (by accident) and never had a problem with my PAR, Shurflo, or Flojet pumps.
Old 04-05-2014, 05:07 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Diaphragm pumps are pretty tolerant of being run dry.
Impeller pumps (like a macerator discharge pump), not so much. Impeller pumps tend to overheat when run dry because they are cooled by the water they pump.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-05-2014, 06:55 AM   #7
sfalvo's Avatar
1977 25' Tradewind
Strongsville , Ohio
Thanks for the information. I appreciate it.
Old 04-05-2014, 10:20 AM   #8
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 41
Mine has run dry for days with no problem. That happens because it hard to hear when it is pumping dry and I don't notice that the switch is on. Not a good practice I'm sure but it happens. Mine is a SHURflo Revolution BTW.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Great deal but No Title, Should I get it? How to get title in MI or NY? Gypset Title, VIN & Registration 13 03-28-2017 06:15 PM
How did your airstream get damaged? 1cericks1 Exterior Restoration Forum 31 03-30-2014 08:20 AM
2007 Safari with water-damaged floor! TennisMan Floor Finishes 7 09-18-2009 09:51 PM
Boy, am I pumped! ALANSD Mechanics Corner - Engines, Transmission & More... 13 07-08-2005 08:49 AM
1991 34' Floor water damaged in rear. potatoes Repairing/Replacing Floor &/or Frame 11 06-03-2005 04:45 PM
