Old 09-13-2005, 09:18 PM   #1
1963 19' Globetrotter
Moline , Illinois
will atwood drain from cold intake
I just finished replumbing my trailer and put in a lowpoint drain which is also connected to the cold water supply line on my new 6 gal heater. I figured I could open a hot faucet (for venting) and drain the heater back out the intake. My brother said the only way you can drain this heater is through the plug on the front which is going to be a challenge with my old Bowen door which I worked hard to keep. Will my way do the job?
63air is offline   Reply With Quote
Old 09-14-2005, 01:57 AM   #2
Not if it's like my Attwood water heater. Sorry. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 09-14-2005, 04:50 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Depends on how your trailer's plumbing is routed. If the water can go from the lowest point, out of the trailer, then maybe you can open the overpressure vent in the top of the water heater, and it will be sucked out. But more likely, you will have to drain it through the bottom drain on the front.
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 09:39 PM
