Old 05-25-2010, 09:30 AM   #1
1976 31' Sovereign
Ocala , Florida
Why can't I use an electric water heater ?
Is it because they pull to much amperage ? More than the have at most c/grounds ? What do most c/grounds supply ? I wanted to put a small electric w/heater in the closet and do w/o the propane all together, everything else is electric soooo - - ?
Thanks !!
rbrinkley is offline   Reply With Quote
Old 05-25-2010, 09:48 AM   #2
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
two ways water heater exists. So you can install one. But you have to check if you won't overload circuits if use with AC, or MW...
Some forum members will tell you more about the electrical issue.
suburban has some : Suburban > Products > Water Heaters > Specifications
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 05-25-2010, 09:56 AM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
You can get a dual powered water heater. They use propane, or electric (or both) depending on your needs. If you go the route of using electric you will want to look into how much amperage you camper is set up for. The water heater on electric pulls a good deal of juice. In my set up I can not use the water heater in tandem with the AC or presumably with electric heat. This can be dealt with by putting in a larger breaker box though.
I would try and stay with a RV type heater since it wont require extensive reworking of the camper.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-25-2010, 09:58 AM   #4
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Back when we had a SOB Trvel Trailer, we did not trust the propane hot water tank system so we had electricians come in and install a twenty gallon electric one and they fixed it to be right in the living area and we sat a tv on top of it. It used a lot of electricity and you had to juggle appliances in order to get the hot water...this also includes and incredible electric bill to go with it.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 05-25-2010, 10:17 AM   #5
1976 31' Sovereign
Ocala , Florida
Thanks !! My 78 Excella is basically stock, and WELL used. The couple I got it form went to every state, and almost every providence in Canada. as well as their last trip - Alaska at the ages of 84. Soooo - It's in a state of partial gutting. Space is not an issue since I removed some of the cabinets, etc. We will only use it (mostly) at campgrounds here in Fla.
Does anyone know what kind of amperage this camper is set up for ? Is that in my manual ? Can I just put in another breaker/line for the w/h ?
Old 05-25-2010, 10:26 AM   #6
Kevin245's Avatar
30 amp service is a campground standard for a trailer of your size, but you can also get 50 amp sites. If you were to add a 2nd air conditioner as part of your re-do then you might consider the higher service application.
Best of luck,
Kevin
Eleanor Roosevelt
Old 05-25-2010, 12:40 PM   #7
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
One solution is to install a "RV Water Heater Lightning Rod" in your existing unit, it only draws 4 amps, but at only 425 watts it may take a while to heat up the tank.
6 Gallon RV Water Heater Lightning Rod
snake is offline   Reply With Quote
Old 05-25-2010, 12:44 PM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
You Airstream is limited to 30 amps to redo for 50 amp service is expensive but can be done
Reason for propane is some folks don't camp in full hook up camp grounds.
You can buy duel electric / propane water heaters but will be limited in what other appliances can be used at the same time when heating with electric.
With a 6 gallon hot water tank propane with recover much quicker than electric.
Garry
Old 05-25-2010, 12:57 PM   #9
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Originally Posted by rbrinkley View Post
... do w/o the propane all together, everything else is electric soooo - - ?
Thanks !!
What will you use for cooking?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-25-2010, 01:21 PM   #10
1964 24' Tradewind
Calgary , Alberta
We put in a 6 gallon, electric only hot water heater in our '64 Tradewind. We have it parked for the summer at campsite with electrical included in our annual fee so there was no reason to get a (much more expense) system designed specifically for an RV. We are also using a regular, electric only fridge and have propane only to the stove. This is contrary to the standard advice on airstreams, but we don't really have plans to use the trailer without electricity.
We've had no issues with it drawing too much power, but we are also in a climate where A/C is not required so nothing else is much of a power draw.
Blanchard is offline   Reply With Quote
Old 05-25-2010, 01:36 PM   #11
1976 31' Sovereign
Ocala , Florida
Microwave, BIG toaster oven (pizza size ) and a 2 burner hot plate. We don't do alot of HEAVY cooking when we camp. We grill too. She usually has 3 or so meals (one pot stuff) chilli, chicken pot pie, etc already made and frozen so we just put one in the sink on the way out in the a.m. and heat-n-eat. We camp to SWIM !! in the springs of fla. So we swim all day and eat at night ! Maybe some bisquits for b-fast, but that's about all.
Old 05-25-2010, 01:37 PM   #12
1976 31' Sovereign
Ocala , Florida
We stay 4 days max and flat rate for campsite per day so electrcity usage doesn't factor in.
Old 05-25-2010, 03:42 PM   #13
guy99's Avatar
Images: 16
I doubt you could use your microwave, or your toaster oven, or maybe even hotplate while the AC is on, at least not with 30 amp service. Our rig (84 MH) has a switch which lets you choose either Microwave OR AC.
Old 05-25-2010, 04:11 PM   #14
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
Our unit came with a Lightning Rod in the water heater. It heats up fairly fast--but we don't use that much hot water when camping usually. We often don't even turn on the propane in hot weather--we mostly do easy meals using the microwave and toaster oven usually.
The LR is not wired into the trailer, in our case. It has a separate cord I just plug into the campground power pole--in addition to the 30amp cord. Works fine that way, no problems.
If your water heater is in good shape otherwise, it may pay to just retrofit it with one of these Lightning rods.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Electric Water heater on 56 Safari Rick56Safari Water Heaters, Filters & Pumps 2 04-10-2018 04:41 AM
To Go All Electric on the Water Heater? Excellaphant 1987 - 1989 Excella 14 07-20-2011 02:20 PM
Point of Use Electric Water Heater ? 60's Iron Water Heaters, Filters & Pumps 6 08-25-2009 09:41 PM
Propane to Electric Water Heater Conversion childst Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-11-2009 10:11 AM
Gas and Electric water heater and furnace Jim Casavant General Motorhome Topics 4 08-07-2007 07:28 PM
