Old 05-25-2010, 07:15 PM   #15
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
I added the electric conversion and still use 30a sites with no problem. Haven't had an occasion where I ran out of hot water either.......
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
--Mark Twain
Alwhisman is offline   Reply With Quote
Old 05-25-2010, 07:26 PM   #16
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
The issue is if you start using additional heavy power using appliances or several smaller users. For example if the water heater and AC are pulling power at the same time you are likely to flip a breaker.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-25-2010, 09:24 PM   #17
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
I have an electric only hot water heater that looks just like the one in my house but much smaller. We have never had an issue with not having enough electricity and popping breakers. We use the air, microwave, etc but I did run a dedicated line to the hot water heater.
63silver
63Silver is offline   Reply With Quote
Old 05-25-2010, 09:35 PM   #18
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
So long as the campground 30a voltage is good, I always run my 13.5 AC/Heat Pump and the electric water heater at the same time with no problem. I just check my plug-in voltmeter. If the voltage is well up in the green with the AC on, I turn the electric water heater on. I almost never need to use the propane side of my water heater. You can not do this with a 15.0 AC/Heat Pump, it pulls too much current.
I have an auto transformer that I chain to the power post if the campground voltage is marginal. In that case, I usually run only the AC/Heat Pump so as not to rob too much power from other sites. I usually find just a few times in the summer season when I am in a campground where the power is that marginal.
John W. Irwin
WBCCI #9632
Old 05-25-2010, 09:38 PM   #19
Ottawa , ON
Can you describe the autotransformer? I'm assuming you use it to bump the voltage up? So then, I'm guessing it has a means of varying the voltage it puts out...
Old 05-25-2010, 10:34 PM   #20
Pahaska's Avatar
Hays County , Texas
The autotransformer plugs in between the power pedestal and the cord to the trailer. It senses for low voltage and boosts the voltage only if it is low. The boost in voltage comes at the expense of pulling more current, so I have to be careful and not use more than the AC/Heat Pump when it is plugged in in order not to blow the breaker on the power pedestal. The increased voltage makes the AC work a lot better and protects the AC compressor.
These autotransformers are expensive, about $300, but I found mine at a flea market for $100.
John W. Irwin
WBCCI #9632
Old 05-26-2010, 05:07 AM   #21
Ottawa , ON
Interesting. Is there a make/model on it? It sounds like more than just a transformer, if it senses and adjusts by itself.
Do you happen to have a photo handy?
Old 05-26-2010, 05:50 AM   #22
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
50 Amp Autoformer - Item - Camping World
Old 05-26-2010, 06:01 AM   #23
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I use electric
I have used a 15 gal. Kenmore electric water heater and Carrier 13.5 A/C in a 69 Caravel, a 66 Caravel for years. Never had a problem. Fast heat up and lots of hot water. My current Flying Cloud had been converter several years ago to a 15 gal. electric water heater and a 13.5 Dometic. No problems...yet?
Old 05-26-2010, 07:01 AM   #24
Pahaska's Avatar
Hays County , Texas
Mine is at the storage yard, so I don't have the info handy.
I have a 30a model of the same make as overlander63 posted a link to. Quite a bit smaller, but looks the same. Mine is quite heavy, so a 50a model would be a real back breaker.
I'm often tempted to wire mine in permanently.
John W. Irwin
WBCCI #9632
Old 05-26-2010, 07:48 AM   #25
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Flipped my breaker
I tried to run both the AC and WH on electric the other day (AC on low) and flipped one of my breakers. I assume they are on the same circuit so that might be the issue.
Rodney
and the
My Blog
Old 05-26-2010, 08:27 AM   #26
Pahaska's Avatar
Hays County , Texas
They should be on different breakers unless this was a late addition and someone put the WH on the AC breaker.
More likely, the AC breaker popped due to the starting current of the AC. That is the most critical time. Given good input voltage, there is actually less chance of popping a breaker in the hottest summer days because the AC runs continuously and there are fewer peak demands.
John W. Irwin
WBCCI #9632
Old 05-26-2010, 08:38 AM   #27
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
The AC had been running for some time when it happened. Both the AC and WH are late additions. I added the WH earlier this year and replaced the AC over the winter so I guess the someone would be me. One of the projects I have in mind is reworking the breaker box, but since I spend so much of the time off as opposed on grid, it really isn't a priority project.
Rodney
and the
My Blog
Old 05-26-2010, 09:26 AM   #28
Pahaska's Avatar
Hays County , Texas
This can happen. Circuit breakers dissipate a certain amount of heat. The heat can build up over time and makethe breaker pop.
John W. Irwin
WBCCI #9632
Electric Water heater on 56 Safari Rick56Safari Water Heaters, Filters & Pumps 2 04-10-2018 04:41 AM
To Go All Electric on the Water Heater? Excellaphant 1987 - 1989 Excella 14 07-20-2011 02:20 PM
Point of Use Electric Water Heater ? 60's Iron Water Heaters, Filters & Pumps 6 08-25-2009 09:41 PM
Propane to Electric Water Heater Conversion childst Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-11-2009 10:11 AM
Gas and Electric water heater and furnace Jim Casavant General Motorhome Topics 4 08-07-2007 07:28 PM
