Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 02-27-2015, 10:52 AM   #1
To Gulls
To Gulls's Avatar
2007 25' Safari FB SE
Pensacola , Florida
Where is the water pump?
We have a 2007 25' Safari FB SE and the water pump doesn't work. Where is the pump located so I can find out the model I need to replace it with?
To Gulls is offline   Reply With Quote
Old 02-27-2015, 11:07 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If it is like our 2005 Safari 25FB, the water pump is located under the wardrobe. You can access this area by opening the little hinged door with the furnace vent in it. It is hinged at the back of the trailer.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 02-27-2015, 11:18 AM   #3
Antiquepedaler
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
Same with our '10.
Antique Pedaler
2021 Caravel 20 FB
Antique Pedaler is offline   Reply With Quote
Old 02-27-2015, 11:31 AM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
On my 2008 Classic 25fb the water pump is under the fridge but there is an access hatch on the adjacent wardrobe floor. You can get to it easier if you remove the back panel from the small cabinet under the fridge. There is a lot of stuff in the way; heat ducting, wires, plumbing and the water pump is behind all this stuff.
Kelvin
Old 02-27-2015, 01:40 PM   #5
Rich W's Avatar
I'm In , Kentucky
Our 2006 23' Safari has it where the others are; under the left wardrobe, just left of the converter panel. There is no handle on the door, just get your fingers on the top right and it swings left. AS support said it was under the floor of the wardrobe and the panels could be lifted up, but that wasn't correct. If you don't have the door below it might be you need to lift the wardrobe floor.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 02-28-2015, 07:23 AM   #6
To Gulls
To Gulls's Avatar
Pensacola , Florida
Many thanks to you all! Found it! Now, it is a Smart Sensor 5900-0211 and the reviews on Amazon are awful! Suggestions on replacement?
To Gulls
Tami & Brenda - Pensacola, FL
2007 25FB Safari Special Edition LS
2008 White Toyota Tundra 5.7L V8
"There is no present like the time."
Old 02-28-2015, 08:43 AM   #7
moosetags's Avatar
Shurflo makes a wide variety of high quality RV water pumps. I have use two different models in my truck camper. They are rebuildable and repairable. I carry a spare in my truck camper.
Look through the Shurflo catalog and on-line reviews of the various models. I think that you will find a good replacement pump.
Brian
Old 02-28-2015, 09:49 AM   #8
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Turn it on and listen ! Hard to miss it unless you have a hearing impairment ...
Old 02-28-2015, 01:57 PM   #9
iowaroots's Avatar
Dallas Center/Des Moines , Iowa
If you couldn't hear it to find it....then maybe.....it is not turned on?? Just reaching for straws..
Good luck with the replacement.
iowaroots is offline   Reply With Quote
Old 02-28-2015, 06:36 PM   #10
moosetags's Avatar
Looking at earlier post, he has already located it.
Brian
Old 10-15-2018, 01:09 PM   #11
Leander's Avatar
2018 28' Flying Cloud
Monroe , Georgia
2018 AS Flying Cloud 28 RBQ - water pump location
Owners Manual is not correct...the water pump for my 2018 28 FC is not under the fridge but rather under the microwave.
Leander is offline   Reply With Quote
Old 10-15-2018, 01:41 PM   #12
Sag Harbor , New York
FYI this thread is 3 1/2 years old, and the OP found the pump in his 2007 25' AS.
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 09:52 AM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
