Old 09-29-2010, 09:00 AM   #1
Mike&Ali's Avatar
1964 22' Safari
Dayton , Ohio
Where does the water pump go in relation to the tank?
Doing a complete remodel of a 64' Safari and I thought there was a specific location for the water pump in relation to the water tank. I can;'t remember what thread I read it in.
Should it be mounted above, below, next too?
Thanks for the help!
Mike&Ali is offline   Reply With Quote
Old 09-29-2010, 09:11 AM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
All I know is that the pump should be between the tank and the first fixture. My Safari has the tank under the floor between the axles and the pump is in the bathroom. The tank on my Liner is under the floor in front of the axles and the pump is in front of the kitchen.
Bill
Just my personal opinion
wkerfoot is offline   Reply With Quote
Old 09-29-2010, 09:11 AM   #3
The 64 water tank was under a rear bed, as I recall, but some were under the front window
The water tank was then move up front, under the window, with the pump next to it, and again, if I remember correctly, on the road side.
The filler was also on the road side.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-29-2010, 09:04 PM   #4
AL’ UM- MONEY's Avatar
1976 31' Sovereign
2000 33' Land Yacht
Ball Ground , Georgia
Question on fresh water
I hope this doesn't devert your train of thought. I'm starting to work on my 1976. I assume there is a check valve somewere between the pump and shore water pressure so the fresh water tank won't backfill through the pump. Does anyone have a diagram or explaination of how the two systems seperate from each other. Is the pump self priming and if all joints are tight pull water from the tank. While I'm at it can someone driect me to how the sanitize a 30 year old tank that hasn't had water in it.
AL’ UM- MONEY is offline   Reply With Quote
No water at sink when using internal pump/tank RichHog Plumbing - Systems & Fixtures 10 10-26-2016 01:44 PM
Replacement Pump for pressurized water tank muddy_hollow Fresh Water Systems 26 03-15-2010 06:06 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
Fresh Water Tank to Grey + Shower Pump? foshejh Fresh Water Systems 7 12-08-2005 09:22 AM
pressurized galvanized tank vs. water pump 59er Water Heaters, Filters & Pumps 12 05-03-2005 03:58 AM
