Old 10-01-2010, 12:49 PM   #1
Mike&Ali's Avatar
1964 22' Safari
Dayton , Ohio
Where does the water pump go?
Doing a complete remodel and am wondering where the water pump goes in relation to the tank. I read somewhere that there is a specific location in relation to the tank (side, above, etc.). My tank will sit on the floor (64 safari).
Mike&Ali is offline   Reply With Quote
Old 10-01-2010, 12:52 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Mine is bolted down on the floor near the outlet on the tank, connected by a short hose. What kind of water pump? Is it a vintage unit, or a regular new shur-flo type pump?
Stephanie
Old 10-01-2010, 03:55 PM   #3
Mike&Ali's Avatar
1964 22' Safari
Dayton , Ohio
Yeah, it's a newer type - just a couple years old.
Old 10-01-2010, 04:02 PM   #4
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Those pumps will suck water up from several feet - they are self priming pumps so you can put it just about anywhere.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 10-01-2010, 08:10 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Near the tank
I would install it as close to the tank as possible, making sure it is easily accessible for maintenance and winterizing. Of course there is the wiring consideration as well. Longer wires and shorter suction is better in my opinion. It's easy to find a leak in the pressurized side of the system as opposed to the suction side.
Old 10-02-2010, 06:24 AM   #6
Mike&Ali's Avatar
1964 22' Safari
Dayton , Ohio
excellent! Thanks for the help
Old 12-31-2010, 01:31 PM   #7
1972 Argosy 20
2000 36' Land Yacht XC Diesel
narrows , Virginia
where is the water pump in a 2000 airstream land yatch xl thirty six.. I hear it behind the hamper behind the toilet .. cant figure how to get to it.. also the vdu solder job dident work for me any other options. Is it possible and affordable to replace them.. the noise when it comes drives me batty..thanks
jtrivett is offline   Reply With Quote
Cycling Water pump with no water leaks TheProfessor Water Heaters, Filters & Pumps 4 03-30-2010 06:54 PM
Water Pump Vomits water out of faucets! thoreaulycra Water Heaters, Filters & Pumps 5 12-19-2008 11:12 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
